More Decimal Places in the Default Axis GUI
- squan09
09 Feb 2016 20:45 #69903
by squan09
Replied by squan09 on topic More Decimal Places in the Default Axis GUI
Have you been able to get this to work? Do you know if you will actually be able to control to that resolution or will it only be an extra decimal on the display?
- BigJohnT
- Thank you received: 994
11 Feb 2016 12:29 #70005
by BigJohnT
The display precision is not the precision used by the software. Numbers may have any number of digits, subject to the limitation on line length. Only about seventeen significant figures will be retained, however (enough for all known applications).
JT
Replied by BigJohnT on topic More Decimal Places in the Default Axis GUI
Will this mod give you that precision if you call for it? I have added gear reducers to the ball screw to add precision by 100. I would like to be able to call for it in g code instead of having to remember of dividing what i call for by 100.
Thanks for all your great posts.
JT
- cyrut2
28 Apr 2016 11:35 #74008
by cyrut2
Replied by cyrut2 on topic More Decimal Places in the Default Axis GUI
I had to rebuild the dressers and other items on the machine now its closer to test. I have some TESA units for reference but i can only get between 40-50 millionths resolution. There is alittle backlash but im not to worried about that now i need to start grinding and testing. I know it does go below 40 millionths but i cannot see or very repeatablity for CP or Cpk.
- cyrut2
28 Apr 2016 14:38 #74014
by cyrut2
You are right i see that the resolution goes in moves of .000039 inch which comes out to about one step. I havent done micro stepping because i cant afford to loose steps due to torque calculations we are at the limit. Which comes to my next problem.
When i call for a G00 i have a crazy high feed rate which i have set in the steppnc and does not respect. I need to max the feed rate of g00 to about 10in/min. How can i override this.
- Thank you received: 1482
28 Apr 2016 15:50 #74016
Replied by Todd Zuercher on topic More Decimal Places in the Default Axis GUI
The ini axis settings are in machine units/second. So for an inch machine putting 10 in for the MAX_VELOCITY will give a max speed of 600 in/min. So to get the speeds you want don't forget to divide your inches/minute by 60 when you put your entries in the ini file.
29 Apr 2016 06:34 #74049
Despite what is often said, microstepping does not reduce motor maximum torque. It does reduce the torque-per-step.
If you are at the torque limit then it is likely that the motor will sit on the full steps anyway, regardless of microstepping.
However, for finishing passes and low loads you might well see an improvement in machine accuracy with higher microstepping.
Replied by andypugh on topic More Decimal Places in the Default Axis GUI
Time to create page: 0.103 seconds
