Wire size for controller board
30 Mar 2014 04:42 #45386 by jonesturf
Wire size for controller board was created by jonesturf
Forgive me for asking a silly question like this but I'm curious as to whats the smallest wire size I can get away with for wiring up a Mesa 7i76. I have plenty of wire from the old electronics but most of it is 16 GA or bigger and(which is pretty tight) and then some really small stuff ...probably 24 gauge. I know it probably doesn't take a lot but I don't limit anything going to my drives and such.
30 Mar 2014 06:06 #45393 by PCW
Replied by PCW on topic Wire size for controller board
24 gauge should be fine though a bit fragile
I would not use anything larger that 18 Gauge in the 7i76 terminals
30 Mar 2014 07:26 #45397 by andypugh
Replied by andypugh on topic Wire size for controller board
I'm curious as to whats the smallest wire size I can get away with for wiring up a Mesa 7i76..
If you go too small then you can't get ferrules and crimps to suit the wire. But the signal wires can be extremely small.
Time to create page: 0.071 seconds
