8i20 brushless servo hall sensor set up
- johns00056
13 Apr 2014 23:13 #45913
by johns00056
Replied by johns00056 on topic 8i20 brushless servo hall sensor set up
The rotor angle counts like you said it should.
clockwise
0 true true false
.1666667 tff
.3333333 tft
.5 fft
.6666667 ftt
.8333333 ftf
the pattern is 110 100 101 001 011 010 110 100 which looks like pattern 30.
I can't get q mode to work.
qi mode works and the rotor-angle counts in the same direction.(but with smaller increments)
It is an 8 pole motor.
Each hall changes state 8 times per motor revolution.
The rotor-angle display reads zero 4 times per motor revolution. (in both qi and h modes)
On a plus note-- I got the jog wheel MPG to work!! (in cfg=qi mode)
clockwise
0 true true false
.1666667 tff
.3333333 tft
.5 fft
.6666667 ftt
.8333333 ftf
- johns00056
13 Apr 2014 23:24 #45914
by johns00056
The origional Fanuc encoders (which I still have) are alpha A64 type A860-0360-v501 with 13 wires coming
out, and type A860-0315-t101 2000p with 16 wires.
Using LinuxCNC Master sounds intimidating for a beginner like myself.
- Thank you received: 4966
13 Apr 2014 23:34 #45915
Is the motor locked in positions where it doesn't spin? I think that there are only three options (spin, lock or vibrate) that can happen with the commutation wrong. If you can turn it by hand then it looks like a problem with the current being supplied.
Replied by andypugh on topic 8i20 brushless servo hall sensor set up
I have tried almost all of the hall patterns and nothing happens, other than a very faint
wine at the motor with every pattern.
- johns00056
14 Apr 2014 00:28 #45916
by johns00056
The motor spins freely with every pattern.
When I do the above shown halrun session and the 8120 servo drive is enabled, the only result is a very faint wine sound that I can only hear if I hold my ear 3 inches from the motor. The pitch of this sound changes as I turn the motor with my fingers.
The sound stops if I un-unable 8i20.
I agree, I think that something is not linked properly in the hal program to supply current to the motor.
14 Apr 2014 02:28 #45918
I just noticed, you have a LinuxCNC version which has an 8i20 amp-enable pin, and furthermore, it is false.
I do wish I had noticed that earlier.
You need to setp that to true. (or link it to something appropriate in HAL).
The pin is not present in Master or 2.6.
halcmd: show all *8i20*
Loaded HAL Components:
ID Type Name PID State
Component Pins:
Owner Type Dir Value Name
5 bit IN FALSE hm2_5i25.0.8i20.0.0.amp_enable
5 float IN 0.5 hm2_5i25.0.8i20.0.0.angle <== ang
- johns00056
14 Apr 2014 04:07 - 30 May 2014 20:00 #45919
by johns00056
THAT WAS IT!!
It runs great now with pattern 22, I have not tried any other patterns yet.
Thanks for all of your help, I think that I am (very slowly) getting the hang of it.
halrun
enter
halcmd:
(copy,paste the commands below here)
loadrt hostmot2
loadrt hm2_pci config="sserial_port_0=0200xxxx"
loadrt threads name1=thread1 period1=1000000
loadrt bldc cfg=h
addf hm2_5i25.0.read thread1
addf bldc.0 thread1
addf hm2_5i25.0.write thread1
addf hm2_5i25.0.pet_watchdog thread1
net h1 hm2_5i25.0.7i84.0.1.input-24 bldc.0.hall1
net h2 hm2_5i25.0.7i84.0.1.input-25 bldc.0.hall2
net h3 hm2_5i25.0.7i84.0.1.input-26 bldc.0.hall3
net ang bldc.0.rotor-angle hm2_5i25.0.8i20.0.0.angle
setp bldc.0.pattern 22
setp hm2_5i25.0.8i20.0.0.amp_enable true
loadusr halmeter pin hm2_5i25.0.8i20.0.0.current
loadusr halmeter signal h1
loadusr halmeter signal h2
loadusr halmeter signal h3
setp hm2_5i25.0.8i20.0.0.current 0.1
start
halrun
enter
halcmd:
loadrt hostmot2
loadrt bldc cfg=h
addf bldc.0 thread1
start
Last edit: 30 May 2014 20:00 by johns00056.
14 Apr 2014 04:19 #45920
Sorry it took so long to spot the problem.
The best combination for you is probably "qhi" if you liked "qi" mode. You get full torque from the start using trapezoidal commutation and switch to sinusoidal at the index.
"qh" switches to sinusoidal at the first hall transition. (Which works well when the encoder index alignment is not known)
THAT WAS IT!!
It runs great now with pattern 30, I have not tried any other patterns yet.
- Thank you received: 5196
14 Apr 2014 04:30 #45922
A860-0315-t101 2000p is a standard 2000 line (8000 count/turn) quadrature encoder with index
it has 4 bit Fanuc commutation signals instead of normal Hall signals but I am pretty sure the
BLDC comp can deal with these.
A64 type A860-0360-v501 is a 65536 count/turn absolute encoder with a 1024 count/1/4 turn commutation track
This would require LinuxCNC master to run but uses only 4 wires exclusive of power (no Halls no index etc)
Replied by PCW on topic 8i20 brushless servo hall sensor set up
Time to create page: 0.103 seconds
