Requested tool 4 not found in the tool table
05 Apr 2014 02:56 #45568 by 71GA
I created the excellon file with EAGLE and then I converted it into the drill.ngc file. If I open this file with LinuxCNC I get an error:
What does this mean? Do I have to edit the machine configuretion file or is it something wrong with my drill.ngc file. I included
the later as an attachment to this post so you can take a peek - it is quite small
File Name: drill.ngc
File Size:2 KB
05 Apr 2014 03:20 #45569 by emcPT
In this error, the error says it all.
You must add a tool (number 4 in this particular error) to your tool table. You can edit the tool table in File->Edit Tool Table (top menu). But probably is better to read some documentation before you really start machining.
The following user(s) said Thank You: 71GA
Time to create page: 0.061 seconds
