Using Touch Off with Soft Limits
- J64
05 Apr 2014 10:54 #45574
by J64
Using Touch Off with Soft Limits was created by J64
Hi, hope this is the right place for this. I'm having a hard time setting up my project. I used MeshCam to create the G-Code and have my 3 axis machine homed. It's a 2D cut. The problem is when I load the file, it displays outside the cut area(red dotted area), so I used the Touch Off button to adjust each axis. But then I get an error for exceeding soft limits. What am I missing?
- Rick G
- Thank you received: 155
05 Apr 2014 13:10 - 05 Apr 2014 13:10 #45577
by Rick G
Replied by Rick G on topic Using Touch Off with Soft Limits
O.K.
Make sure you have a g code for a part that will fit in the working area of your machine.
After you start linuxcnc you home the machine, then jog the machine to where you want to start working, the touch off your axis there.
If X0 Y0 is the lower left corner of the work and Z is the top of the material, jog to that position and touch off as X0 Y0 Z0.
Or jog to whatever position MeshCam used as a reference point and touch off there.
Make sure your machine and the g code are in the same measuring system metric or imperial G20 G21.
Which axis shows the problem?
Rick G
Rick G
Last edit: 05 Apr 2014 13:10 by Rick G.
- J64
06 Apr 2014 07:34 #45605
by J64
Replied by J64 on topic Using Touch Off with Soft Limits
Alright, so I was able to change the G Code to run within my work area. I'm having problems with the Z axis. I guess Im not sure whether its something in the CAM or in LinuxCNC I should be tweakin but Im looking for the right way to set up the Z. I broke a couple bits already.
- Rick G
06 Apr 2014 14:17 - 06 Apr 2014 14:18 #45607
by Rick G
I have never tried MeshCam, so perhaps someone who has will jump in.
I would Start with your Cam set up. Normally there is a section where you set up your material. length, width, thickness and safe Z travel height.
If you set Z 0 as the top of the material in your Cam program and all cuts are downward. I also set my X0 and Y0 to be the lower left corner of the material on a router or the top left if using a vise on the mill.
The important thing is that both the Cam program and linuxcnc are set the same.
If your Cam is set for Z 0 as the top of the material jog your Z axis down to the top of the material and then "touch off" Z as Z0.
This might help...
gnipsel.com/linuxcnc/g-code/mill02.html
To avoid breaking bit try setting Z above the work and let the machine "air cut" the part to see what is going on.
You can also post the code you created for us to look at.
Rick G
This might help...
Rick G
Last edit: 06 Apr 2014 14:18 by Rick G.
- gww250
06 Apr 2014 17:32 #45611
by gww250
Replied by gww250 on topic Using Touch Off with Soft Limits
Also take a look at your meshcam setup as you can specify where the part's origins are. Typically you want Z0 to be at the top surface of the blank but I've often seen imported CAD drawings force this to deeper into the model. If so change it within Meshcam.
- pi.r
06 Apr 2014 23:10 #45620
by pi.r
Replied by pi.r on topic Using Touch Off with Soft Limits
Watch out for tool length compensation..!
Tool length compensation can give "unexpected" shifts in Z-level. You can read the current compensation from the "TLO Z" value in the DRO.
If MeshCam is configured to use tool length compensation, you will have to manually load the requested tool in LinuxCNC and enable the tool length compensation with "G43", before you make the Z-axis touch off.
- J64
07 Apr 2014 11:56 - 07 Apr 2014 11:59 #45640
by J64
I really think my problem is in Meshcam. Setting up the Z 0. I tried a few different heights and tried those different programs and it's getting closer to where it should be. There's an option in Meshcam to set Z0 as Top, Middle, Bottom of material, but even with this code, when I try to run it, the bit doesnt reach the material. It 'air cuts' it. Right now, after I home all 3 axis, jog the Z to top of material, Touch Off as ZO, the project shows a little below that point, maybe an couple inches. This seems to be causing the problem, so I then Touch Off the Z to a number that brings the project closer to the bit in the GUI. I'll have some time tonight to mess with it again. Thanks for the replies. Closer to getting this thing running.
Last edit: 07 Apr 2014 11:59 by J64.
- cncbasher
- Thank you received: 288
07 Apr 2014 21:04 #45649
by cncbasher
Replied by cncbasher on topic Using Touch Off with Soft Limits
if you set meshcam to the top of the material as Z0 then it should show that as top , not 2 inches below , are your datums all the same i.e all Inch or all metric
if you first make sure all compensations are turned off and the repeat the exercise . before working with tool compensations
- gww250
07 Apr 2014 22:05 #45657
by gww250
what kind of mill and controller do you have. I think maybe that you're Z axis is trying to run 'reverse' which I have seen before on some new system setups.
- Rick G
08 Apr 2014 14:10 #45682
by Rick G
In addition take a look here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Coordi...t_what_should_you_do
Rick G
Rick G
Time to create page: 0.096 seconds
