custom M code
- viski
08 Apr 2014 00:37 #45664
by viski
custom M code was created by viski
I have created M100 and M101 code, write it in HALUI section, restart GUI and PC but when i type it in MDI ( F5) i get error mesage: not known M code!
Do i have to write it in more sections in INI file ?
- emcPT
- Thank you received: 139
08 Apr 2014 01:16 #45665
by emcPT
Replied by emcPT on topic custom M code
The file must have execution permission (this is the most commun fault).
The M in the file must also be upper case.
- ArcEye
- Thank you received: 758
08 Apr 2014 13:22 #45679
by ArcEye
Replied by ArcEye on topic custom M code
www.linuxcnc.org/docs/html/gcode/m-code.html#sec:M100-to-M199
has full details.
What it does not seem to mention is that the file must be in the dir pointed to in your ini file by
PROGRAM_PREFIX=
has full details.
PROGRAM_PREFIX=
The following user(s) said Thank You: viski
- viski
11 Apr 2014 02:13 #45814
by viski
Replied by viski on topic custom M code
Thanks, it works!
Problem has been file in wrong directory.
Time to create page: 0.108 seconds
