Jog in oposit direction when hit pos/neg limit sw
10 Apr 2014 17:56 #45785 by jtc
Hi.
I was wondering it it's possible to jog in the opposite direction when, for example the machine hits the Z+ limit.
so, if it touch the Z+ limit, I want do jog in the Z- direction. Is this possible?
I have connected 2 limit switches to axis.2.neg-lim-sw-in and axis.2.pos-lim-sw-in, but if touch one of theses linuxcnc goes to a disable state.
Thanks,
João
10 Apr 2014 18:09 #45786 by cncbasher
if your using axis there is a tick box to disable the limits , and allow you to jog off the limit sw
The following user(s) said Thank You: jtc
10 Apr 2014 20:02 #45791 by jtc
this option shows "disabled", its necessary do connect some pins on the hal file?
10 Apr 2014 20:22 #45792 by Todd Zuercher
Replied by Todd Zuercher on topic Jog in oposit direction when hit pos/neg limit sw
When you bump the limit, Axis goes into the "disabled" or power off state. This is when you click on the Override Limits check box (it is greyed out until you are against the limit). After you click it, you can then press the power button on axis (or F2) to re-enable the drives and jog off the limit.
Time to create page: 0.047 seconds
