5i22 / 7i77 limit switches
14 Apr 2014 08:23 #45934 by greeder88
5i22 / 7i77 limit switches was created by greeder88
I'm trying to get the limit switches set up on the 7i77 and having a problem with understanding the normally closed concept.
I have 12vdc + from my power supply hooked to TB-2 Pin #1
Power supply ground to TB-2 Pin #8.
TB2 Pin #5 has 12v.
My configured axis pins are #9, 10, and 11.
My e-stop pin is configured to #12.
All are -not.
1- Do I have to install firmware? Looks like it was pre-installed but not sure. The cards arrived in the last few weeks.
2- What linkage do I use? Example: #5-#9-#10-#11-#12-#8
Thank you very much.
14 Apr 2014 08:38 #45935 by PCW
Replied by PCW on topic 5i22 / 7i77 limit switches
limit switch wiring is
+12V --> switchT1 --> switchT2 --> 7I77 input
As long as power is wired correctly, you should be good to go
14 Apr 2014 19:12 #45938 by jtc
Replied by jtc on topic 5i22 / 7i77 limit switches
try with the inverted inputs (If I remember correctly)
xx-input-not
João
Time to create page: 0.064 seconds
