8i20 brushless servo drive output amps
- Thank you received: 5013
24 Apr 2014 19:21 #46286
Is the PID output still limited to 1?
The code in the version of the driver you are using is as follows:
251 norm_current = *hal->pin.hm2_current
252 * hal->param.hm2_max_current
253 / hal->param.hm2_nv_max_current
254 * i_const;
So, the "current" pin value is multiplied by the max-current parameter and then divided by the value from the nvram (which you have changed).
In the hal file you posted earlier the line
#setp hm2_5i25.0.8i20.0.0.max_current 15
was commented out, so the max_current defaults to nv_max_current.
So, actually, PCW was correct that the net effect is a current command that scales from 0 to 1.
Looking at the code in 2.6 / master you will need to be aware that the input value becomes actual amps in that version, and all the pin names change.
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.6
Sorry about that.
Replied by andypugh on topic 8i20 brushless servo drive output amps
I have it set to 15 amps and it made a huge difference. The motor has lots of torque and is practically unstoppable with my hands.
254 * i_const;
Sorry about that.
- johns00056
- Thank you received: 3
25 Apr 2014 01:09 #46290
by johns00056
Replied by johns00056 on topic 8i20 brushless servo drive output amps
The motor is running great today. The moving parts weigh more than 2 tons. I have the maximum speed set to 100 inches per minute (that seems plenty fast for me) but it will go faster with no problem.
I ran it for a little while with the min following error set to .0001 inch and .020 max following error (which was my goal) and it was able to do it. ( except when I spun the MPG jog wheel really fast on .010 per increment setting)
#setp hm2_5i25.0.8i20.0.0.max_current 15 --- I commented out this line because it had no effect.
The PID output does not appear to go above 1.
Thanks for all your help. I am sure that I will have many more questions before this project is complete.
25 Apr 2014 06:52 #46294
I think that that is because you have limited it to 1 in the HAL.
If you upgrade to 2.6 you will have to change the PID limit to the max current in amps, and probably re-tune a bit, due to the changes I mentioned earlier.
Time to create page: 0.057 seconds
