another limit issue/homing issue
- cncbasher
- Thank you received: 288
28 Apr 2014 23:45 #46437
by cncbasher
As andy says add debounce and get screened cables , this is typical of noise pickup on low voltage wireing ,and can also be caused by the wire gauge to be smaller than is needed , and therfore your getting voltage and current losses .
Replied by cncbasher on topic another limit issue/homing issue
while the machine is powered on and sitting idle and axis is running but the machine is off according to axis i do randomly see the override limits button become active for a split second but it is not on long enough to do anything with.
Considering that homing is slow, and a small delay (of a few mS) in detecting the switch is not super-critical, and that false-triggering of the limit switches can ruin parts and/or be annoying, it is probably not a bad idea to add debounce to your limit switches (Mine have it)
www.linuxcnc.org/docs/html/man/man9/debounce.9.html
Time to create page: 0.094 seconds
