second daughter board on 5i25 won't communicate
- johns00056
10 May 2014 22:35 #46796
by johns00056
second daughter board on 5i25 won't communicate was created by johns00056
I am trying to use the P2 connector on 5i25 but it will not communicate when I start up .( the red fault light
stays on )
I have a 7i85 on P3 of 5i25, which works fine, and am trying to use a second 7i85 on the P2 connector .
Debug file information:
spindle.hal:108: Pin 'hm2_5i25.0.7i83.1.0.analogena0' does not exist
It finds the board OK when I do a halrun session.
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
5 bit IN FALSE hm2_5i25.0.7i83.1.0.analogena0
I have tried a number of different config strings in the ini file, but it has made no difference.
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i25
CONFIG="num_encoders=4 sserial_port_0=02000xxx"
CONFIG="num_encoders=4 sserial_port_0=00000xxx"
CONFIG="num_encoders=8 sserial_port_0=00000000"
CONFIG="num_encoders=-1 sserial_port_0=00000000"
stays on )
halcmd: show pin
Component Pins:
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i25
- jtc
- Thank you received: 13
10 May 2014 23:10 #46797
by jtc
Replied by jtc on topic second daughter board on 5i25 won't communicate
do you have the correct firmware on the 5i25? to be able to use 2 7i85 boards?
João
João
- johns00056
10 May 2014 23:50 #46799
by johns00056
Replied by johns00056 on topic second daughter board on 5i25 won't communicate
Thanks for the response. The firmware is 7i85x2 so it looks like it should work.
Show pin lists number 0 thru 7 encoders. I presume that means hostmot2 has found both 7i85 boards.
- jtc
11 May 2014 01:27 #46801
by jtc
your error is 'hm2_5i25.0.7i83.1.0.analogena0' does not exist
do you have any 7i83?
- johns00056
11 May 2014 01:42 #46802
by johns00056
I got it working now! I do have a 7i83 connected to 7i85.
the config string was wrong.
The second 7i85 is sserial_ port=1
CONFIG="num_encoders=-1 sserial_port_0=00000000 num_encoders=-1 sserial_port_1=00000000"
This should enable everything. I will x out the sserial ports that I am not using later.
Time to create page: 0.058 seconds
