TB6560 TB6565 3rd gen 4-axis no volts db25 pin 01
- sn1987a
28 Jul 2014 20:25 #49215
by sn1987a
TB6560 TB6565 3rd gen 4-axis no volts db25 pin 01 was created by sn1987a
Hi, I'm configuring one of these for a mill-conversion: www.ebay.co.uk/itm/281364657882?ssPageNa...id=p3984.m1439.l2649
(Yes, another tight-fisted crazy!
Thanks to the wealth of information in the linuxcnc project I now have four motors turning smoothly and satisfactorily.
But my setup only works when i apply a +5V pull-up to pin 1 on the parallel port. For my board this carries a composite, x,y,z-enable signal.
Inspection of the hal-configuration gui shows that the pin is set appropriately, i.e. goes TRUE when the AXIS power button is depressed and the motors are energised (provided the +5V pull-up is applied to pin 1 ).
Without the pull-up connected, I also verified the pin 1 voltage voltage with a DVM and then an oscilliscope. It did remain zero whatever the logic value.
Having to install this pull-up makes me feel a bit dirty; and suspicious that I have misunderstood or missed something important.
1. Is there strangeness in the board design that requires something like a +5V signal on the ESTOP input before it cooperates?
2. Have the wrong sort of parallel port or have I configured wrongly It's a pci express job with a Netmos chip that appears to be doing the job perfectly. (But my knowledge of parallel port modes is a bitscrappy) ?
3. Is there another cause that I haven't even imagined.
I'd really appreciate any comment that will help to clear the doubts before I move on to mechanical phase of the conversion.
Cheers
Cheers
- ArcEye
- Thank you received: 758
28 Jul 2014 23:15 - 28 Jul 2014 23:15 #49224
by ArcEye
My SWAG would be that the enable requires a strong source to operate (bit like the Gecko's charge pump not working unless you enable EPP mode).
The PCIe is undoubtedly 3.3v and probably cannot supply enough
See this thread re the Gecko problem
linuxcnc.org/index.php/english/forum/38-...el-port-card?start=6
Replied by ArcEye on topic TB6560 TB6565 3rd gen 4-axis no volts db25 pin 01
Last edit: 28 Jul 2014 23:15 by ArcEye.
The following user(s) said Thank You: sn1987a
Time to create page: 0.060 seconds
