RTAI_SERIAL
15 Aug 2014 01:05 #49870 by ArcEye
Replied by ArcEye on topic RTAI_SERIAL
Update:-
rtai_fifos is incorporated into rtai_sched in this build, so you already have them.
All systems go then.
15 Aug 2014 01:40 - 15 Aug 2014 02:16 #49872 by H18
Replied by H18 on topic RTAI_SERIAL
OK I am at the step where I perform the
sudo mv /usr/realtime /usr/rt
sudo dpkg -i realtime-3.4-9-rtai-686-pae.deb
I get an dpkg error: errror processing realtime-3.4-9-rtai-686-pae.deb (--install):
trying to overwrite '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/sum2.ko' , which is also in package linuxcnc 1:2.6.2
Ideas?
I added a --force-overwrite to the dpkg command
I am poking arround the /usr/realxxx/modules directory and I see:
"rtai_hal"
"rtai_sched"
"rtai_serial" // thanks
I don't see:
"rtai_fifos" // i need this also - I see your comment about incorp into "rtai_sched" thanks
"rtai_sem" // i need this also - is this in "rtai_sched"?
"rtai_mbx" // i need this also - is this in "rtai_sched"?
I have the setup running the latency tests it looks good and stable.
Thanks,
E
Last edit: 15 Aug 2014 02:16 by H18. Reason: info
15 Aug 2014 13:11 - 15 Aug 2014 13:16 #49886 by ArcEye
Unfortunately, doing an update pulled in packages that were not there before and that caused the clash.. Anyway you solved it.
"rtai_hal"
"rtai_sched"
I don't see:
I am not on a linux box at present, but you should have several symlinks in that
all go back to rtai_sched.
If you want to see exactly what is built in, do
objdump -t /usr/realtime-3.4-9-rtai-686-pae/modules/rtai_sched.ko
Last edit: 15 Aug 2014 13:16 by ArcEye.
15 Aug 2014 20:21 - 27 Aug 2014 01:42 #49889 by H18
OK thanks. I'll check that out.
You made mention of Ubuntu support going away... Do you mean that cnclinux is moving away from ubuntu or is there a community movement away from it?
will be looking at: wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
I have eclipse installed but apps can't be run in debugger, it looks like GDB is not installed....
sudo apt-get install gdb
sudo apt-get update
E
Last edit: 27 Aug 2014 01:42 by H18. Reason: info
Time to create page: 0.055 seconds
