OpenXHC - opensource MPG controller ?
- bartwaw
20 Aug 2014 05:15 #50080
by bartwaw
OpenXHC - opensource MPG controller ? was created by bartwaw
- vre
- Thank you received: 18
20 Aug 2014 07:35 #50085
by vre
Replied by vre on topic OpenXHC - opensource MPG controller ?
If it is compatible with linuxcnc i will build it.
Thanks for sharing.
Thanks for sharing.
- bartwaw
20 Aug 2014 13:36 #50088
by bartwaw
Replied by bartwaw on topic OpenXHC - opensource MPG controller ?
It simulates XHC HB03 HB04 CNC MPG devices.
As i know they are working with linuxcnc.
forgot, heres blog:
blog.fxdteam.com/?page_id=733
I've ased autor, and it should work with such encoders:
www.ebay.com/itm/Encoder-360P-R-Incremen...&hash=item1c3cef9077
forgot, heres blog:
- vre
20 Aug 2014 18:30 - 20 Aug 2014 20:08 #50093
by vre
works with any quadrature encoders... but the encoder you posted is not good for mpg
better take 100ppr encoder with detents for better accuracy and control
Last edit: 20 Aug 2014 20:08 by vre.
- BigJohnT
- Thank you received: 1176
20 Aug 2014 19:35 #50096
by BigJohnT
Replied by BigJohnT on topic OpenXHC - opensource MPG controller ?
Some commercial controls don't use detents on their MPG's, I have one on my BP Discovery 308 VMC and it works fine without detents.
JT
JT
- vre
21 Aug 2014 17:05 #50138
by vre
What software and programmer needed to flash this stm32 board ?
- cncbasher
- Thank you received: 288
21 Aug 2014 17:37 - 21 Aug 2014 17:40 #50141
by cncbasher
Replied by cncbasher on topic OpenXHC - opensource MPG controller ?
dont need any programmer , it's a simple bootloader , so you upload via usb , the download application is on st.com website
or here if you want an open source version
code.google.com/p/stm32flash/
Last edit: 21 Aug 2014 17:40 by cncbasher.
- vre
13 Sep 2014 19:23 #51144
by vre
Which app from st.com must download ? Flash loader Demonstrator ?
The boot0 / boot1 jumpers in what position should be ?
Also can you program without bootloader with usb to ttl converter like this www.ebay.com/itm/USB-to-TTL-Module-Seria...40-STC-/131247902933 ?
Time to create page: 0.082 seconds
