Scale
- bill516
26 Aug 2014 19:52 #50309
by bill516
Scale was created by bill516
Does the scale function only work on whole numbers, i.e 320 400 etc or will it work with a decimal place. I have got it into my head that the scale is based on one step of a stepper motor, the driver step setting and the thread pitch. In my case it is 1.8 deg stepper on half stepping in the driver with a 1.25mm thread pitch, scale comes out of wizard as 320. If I am right then 1 step = 0.003125 mm and to increase of decrease movement by 0.01mm I would need to adjust the scale by 3.2 but if it only works on whole steps then it will be 3 @ 0.009375mm or 4 @ 0.0125mm.
I realise threaded rod is not the best thread to use but its all I have the moment.
Bill
Bill
- ArcEye
- Thank you received: 758
26 Aug 2014 20:22 #50310
by ArcEye
Replied by ArcEye on topic Scale
Hi
I am not certain if you are refering to the SCALE = entry in the ini file or the scale component, assume the former.
The SCALE= figure can be floating point, and should be the number of pulses required to move the axis by one unit, in this case 1mm.
If you are using threaded rod, you may need to check movement in several places, as unfortunately it is unlikely to be consistant, any more than it is accurate.
- bill516
26 Aug 2014 20:53 #50315
by bill516
Replied by bill516 on topic Scale
Sorry should have been more specific. It is the scale in the ini file which the wizard came out with 320. Doing the math it does work out to 320 steps per 1mm travel thats why I was asking if the scale is only whole numbers as you cant get less than a step no matter how much micro steps you have you can only have one.
- ArcEye
26 Aug 2014 22:37 #50323
by ArcEye
That is not actually the case, the stepper drivers move the motor to interpolated postions in between full steps.
A good reason not to have micro-stepping too high, as they are not a physical point of attraction between rotor and magnets with a corresponding rotor tooth, so at some stage you can start substituting guessed for interpolated
This gives some detail as to how it is done
www.omega.ca/prodinfo/stepper_motors.html
............... as you cant get less than a step no matter how much micro steps........
Time to create page: 0.048 seconds
