Mesa 5i20 + 7i39 + 7i33 ???
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
28 Aug 2014 08:43 #50374 by Roguish
Mesa 5i20 + 7i39 + 7i33 ??? was created by Roguish
I have my 5i20 + a single 7i33 working with 2 bldc's via the bldc comp. But, that's only 2 axes...
Can I use a pair (2) 7i39's, or a 7i39 plus a 7i33?
Of course the 7i33 interfaces to additional drives, while the 7i39 is a dual drive itself.
Is there firmware for either or both of these situations?
Where might one find .ini and .hal examples for these?
Thanks.
28 Aug 2014 20:56 #50398 by PCW
Replied by PCW on topic Mesa 5i20 + 7i39 + 7i33 ???
What firmware are you using currently? (file name)
Its possible to make a 2x 7i39+ 1x 7I33 config
  • Roguish
  • Elite Member
  • Elite Member
29 Aug 2014 21:34 #50474 by Roguish
Replied by Roguish on topic Mesa 5i20 + 7i39 + 7i33 ???
PCW, thanks for the reply and querry.
I am using SVTP6_7I39.BIT
N.
29 Aug 2014 22:11 #50479 by PCW
OK that configuration is meant for up to 3 7I39s (6 axis total)
if you want a configuration with 2x 7I39s and a 1x 7I33 its possible but pretty
sure there no standard pinout for that so it would involve some copy-pasting
  • Roguish
  • Elite Member
  • Elite Member
29 Aug 2014 22:14 #50480 by Roguish
I'm testing toward making a demo 3D printer. Yeah, been done before, but it's in preparation for proposing a large scale 3D printer, like xx meters by xx meters by xx meters size.
So, I need at least 3 axes for motion, plus at least 1 more and maybe a couple more, I think.
My demo motors are size 23 bldc w/ encoder (no index, though I may change that).
Full project motors might be anything, except steppers.
  • Roguish
  • Elite Member
  • Elite Member
29 Aug 2014 22:18 #50481 by Roguish
Is there any documentation that describes that file is for 6 axes? Naming convention? or something?
When you say cutting and pasting, are you implying creating a new bit file? compiling or what?
29 Aug 2014 22:50 - 29 Aug 2014 22:53 #50485 by PCW
The SVTP6 in the name means SerVo/ThreePhase/6 axis
You can also get a full pinout of the configuration with
sudo mesaflash --device 5i20 --readhmid
Last edit: 29 Aug 2014 22:53 by PCW.
Time to create page: 0.065 seconds
