Z Axis still moving while next XY Gcode issued?
- gigglerg2
22 Sep 2014 04:16 #51413
by gigglerg2
Z Axis still moving while next XY Gcode issued? was created by gigglerg2
My X and Y have the same step configuration but my Z axis does not.
When cutting, sometimes it appears that the Z axis is still moving up (say to clearance) when the next G code to move X and/or Y is issued. I think there was some error box displayed while running my gcode.
Why would my Z still be moving when it has not finished the command and it is starting to process the next command. The result is my wood work has wrong cuts as Z is still moving.
Any help would be greatful,
Regards,
Regards,
- Rick G
- Thank you received: 155
22 Sep 2014 14:02 #51420
by Rick G
Replied by Rick G on topic Z Axis still moving while next XY Gcode issued?
You might want to post a copy of the g code and double check if there is an error code and what that error code is.
Rick G
Rick G
- cncbasher
- Thank you received: 288
22 Sep 2014 15:45 #51424
by cncbasher
Replied by cncbasher on topic Z Axis still moving while next XY Gcode issued?
it sounds more of a miss configured axis , usually for example the velocity is too high , or trying to run the axis at too high a speed
that it's not capable of holding
post the error , they are their for a reason
it's quite normal to run the z axis at a lower rate then the others as it's having to move against gravity and hold position
perhaps post your hal and ini files as an attachment so we can rule them out also
- BigJohnT
- Thank you received: 1176
22 Sep 2014 23:27 #51436
by BigJohnT
Replied by BigJohnT on topic Z Axis still moving while next XY Gcode issued?
My SWAG is this is a G0 move and you have not set the trajectory planner and are using the default G64 (go as fast as possible while touching at least one point on the path) and you have very slow acceleration on the Z axis.
www.linuxcnc.org/docs/html/common/User_Concepts.html
JT
JT
