corner lock
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Nov 2014 16:47 #52648 by billykid
corner lock was created by billykid
hello
I have a THC analog, I needed a signal to enable and disable this depending on the speed.
everything working I just need this signal.
I tried to see configurations already done, but seeing what I need is quite complicated for me
just an example and do it myself.
Linuxcnc 2.6.3 wheezy on parallel port .
Mauro
01 Nov 2014 19:58 #52652 by Rick G
Replied by Rick G on topic corner lock
It would be helpful if you gave more information. Which THC are you using, hardware, etc.
I use John's THC and just set the variation from command speed and real speed at which the THC is active.
Rick G
  • billykid
  • Platinum Member
  • Platinum Member
01 Nov 2014 20:54 #52659 by billykid
Replied by billykid on topic corner lock
thanks Rick
my homebuilt and analog, THC is totally standalone
I only need one pin to enable and disable a function of speed.
Now, unfortunately, if I leave it permanently switched on when the speed is low, tension rises and falls sharply torch on the workpiece.
I would practically a slider to adjust the percentage of speed and a signal to enable or not.
Mauro
02 Nov 2014 15:06 #52683 by Rick G
You might want to look here as a starting point...
www.linuxcnc.org/docs/html/man/man9/thc.9.html
So I assume you are saying using Hal if the torch is on and motion.current-vel is within your set tolerance of motion.requested-vel then set the pin to activate the THC?
You might want to also look at the sample configs for plasma such as plasma-5i20 plasma -demo for screen shots.
Rick G
  • billykid
  • Platinum Member
  • Platinum Member
02 Nov 2014 20:54 #52688 by billykid
thanks Rick
Yes. m3 activate torch, arc ok = transfer set
G38 for floating switch.
missing deactivation of thc low-speed, I will try to figure out how to use only one of the sample configuration.
Mauro
  • Moderator
  • Moderator
18 Dec 2014 09:48 #54106 by tommylight
Replied by tommylight on topic corner lock
You can try this config, it already has a slider for corner lock and a button for turning it off and on. It does work properly, since i use it offten.
linuxcnc.org/index.php/english/forum/49-...hc-config-that-works
It also has pierce height and cut height adjustable, switch travel and Z-axis speed. It does not need G38 or anything of sorst, it does not need anything Z axis related, it does all the logic in hal with an M3 command.
Regards,
Tom
Time to create page: 0.073 seconds
