x y accuracy
04 Dec 2014 05:28 #53657 by paulstenlund
x y accuracy was created by paulstenlund
My X and Y axis are cutting approx .015/in to short. Can I fix this by changing motor steps per revolution?
Paul
04 Dec 2014 07:19 #53663 by DaBit
Replied by DaBit on topic x y accuracy
If you are sure it is caused by a somewhat wrong pitch of the leadscrews instead of other issues like backlash then yes, you can fix it by decreasing the steps per unit number in the INI file.
04 Dec 2014 20:01 #53682 by BigJohnT
Replied by BigJohnT on topic x y accuracy
I assume your using the Stepconf Wizard... at the bottom of the page is the final number Axis SCALE: No matter what you have in the top 5 boxes the scale is the number to pay attention to. All the other boxes do is help you calculate the scale. In fact you can make all the boxes 1 and enter the scale number in motor steps.
JT
Time to create page: 0.053 seconds
