combined x/y axis home switch
05 Dec 2014 05:34 #53697 by cableman
combined x/y axis home switch was created by cableman
Hello,
i have a machine with home switches for the x and y axes that share input pin 15. the switches are located at xmin and ymax.
The z axis has its own home switch located at z max.
i found settings witch shared pins for all axes but not for just two of them.
i tried :
net max-home-y <= parport.0.pin-15-in
net min-home-x <= parport.0.pin-15-in
but got an error that the pin15 is already connected
how do i configure the hal file for shared pins for x and y axis?
many thanks,
Joa
05 Dec 2014 20:27 - 05 Dec 2014 20:32 #53715 by BigJohnT
Replied by BigJohnT on topic combined x/y axis home switch
One way to connect the same input to two things is with the or component.
linuxcnc.org/docs/html/man/man9/or2.9.html
Are the signal names max-home-y and min-home-x connected to the home inputs for the respective axes?
Attach your ini and hal file.
Also read the basic hal tutorial to get an idea how hal works.
linuxcnc.org/docs/html/hal/basic_hal.html
JT
Last edit: 05 Dec 2014 20:32 by BigJohnT.
The following user(s) said Thank You: cableman
06 Dec 2014 17:24 #53759 by cableman
Replied by cableman on topic combined x/y axis home switch
ok many thanks,
i understand the or function is useful for the case when i want to use two input-pins to trigger the same event. i need one input-pin used for two signals...
but i am sure i got that wrong.... ;)
i managed to get x and z axis referencing in the right way but not the y axis.
my ini and hal files are attached
many thanks,
joa
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
07 Dec 2014 06:07 - 14 Feb 2018 14:15 #53775 by Todd Zuercher
Replied by Todd Zuercher on topic combined x/y axis home switch
There is no need to use more than one signal for this. One signal can be connected to the multiple inputs as needed.
net limit-home-x-y <= parport.0.pin-15-in
net limit-home-x-y => axis.0.home-sw-in
net limit-home-x-y => axis.0.neg-lim-sw-in
net limit-home-x-y => axis.1.home-sw-in
net limit-home-x-y => axis.1.pos-lim-sw-in
Last edit: 14 Feb 2018 14:15 by Todd Zuercher.
Time to create page: 0.119 seconds
