Dual probes using NC and NO inputs
- Delron
16 Dec 2014 07:57 #54047
by Delron
Dual probes using NC and NO inputs was created by Delron
Hello,
Can anyone help me with configuring HAL to accept probing using two inputs?
I'm wanting to use a NC Z-setting tool, and a NO edge finder tool.
I'm thinking I need to "OR" two signals to make this work.
parport.0.pin-11-in would be my normally open input.
parport.0.pin-?? would be my normally closed input.
Any help is much appreciated!
My Hal currently is;
# PROBE
net debounce-probe-in debounce.0.1.in <= parport.0.pin-11-in
net probe-in debounce.0.1.out => motion.probe-input
net probe-in => motion.probe-input
net dout-02 <= motion.digital-out-02
# PROBE
- BigJohnT
- Thank you received: 1176
16 Dec 2014 19:54 #54059
by BigJohnT
Replied by BigJohnT on topic Dual probes using NC and NO inputs
The probe input needs to be a N/O input. So in pseudo code it would go like this.
The syntax for or and not are here linuxcnc.org/docs/html/ scroll down a bit to see them.
JT
motion probe input < or 0 out
or 0 in 0 < paraport 11
or 0 in 1< not out
not in < paraport ?
JT
- Delron
17 Dec 2014 00:34 #54069
by Delron
Replied by Delron on topic Dual probes using NC and NO inputs
Hi JT,
You say "The probe input needs to be a N/O input. So in pseudo code it would go like this."
Are you saying I cannot in anyway use a combination of N/C and N/O inputs?
My z-probe is a Marposs tool setter. It is N/C. For edge probing, I want to use my mill bit and a conductive plate pressed to the edge of work piece. N/O.
Thanks.
Thanks.
- ArcEye
- Thank you received: 758
17 Dec 2014 00:44 - 17 Dec 2014 00:51 #54070
by ArcEye
Replied by ArcEye on topic Dual probes using NC and NO inputs
I think JT is just pointing to the use of an or component
with inputs from NO and not NC, so which ever triggers
it will register
PS
And as you probably saw I had huge difficulty getting the above to display properly
it will register
<**************** NO contact
Probe input <******* OR
<*************** ! NC contact
PS
Last edit: 17 Dec 2014 00:51 by ArcEye.
- Delron
17 Dec 2014 00:51 #54071
by Delron
Thanks all,
I will endeavour to figure it out. My HAL skills are lacking as I only work on the mill and linuxCNC part time.
Cheers!
Cheers!
Time to create page: 0.065 seconds
