State of pin "TRUE' at startup???
30 Dec 2014 01:55 #54374 by mmt
or at least when the power is toggled on
Is this possible and if so what type of code is needed in hal?
30 Dec 2014 05:56 #54391 by cmorley
Replied by cmorley on topic State of pin "TRUE' at startup???
Most driving pins have invert parameters this would change the logic to what you want.
If you are using stepconf : 'amplifier Enable' may be the signal you want.
Chris M
06 Jan 2015 01:28 #54594 by andypugh
Replied by andypugh on topic State of pin "TRUE' at startup???
Can you elaborate?
Some pins are hardware-inverted, (pin 1 for example) but switch-on state might be hardware-dependent.
If you want a pin that is true as soon as the PC is turned on then you might have to look at all the pins with a multimeter to find a suitable one.
Time to create page: 0.055 seconds
