Jog axis after limit switch reached
- TopperH
21 Jan 2015 21:27 - 21 Jan 2015 21:28 #55237
by TopperH
Jog axis after limit switch reached was created by TopperH
Hello all together!
after my LinuxCNC machine travelled into one of the limit switches, it turns itself off and returns a
"joint 1 on limit switch error", as expected.
But I can't switch the machine back on to jog the axis away from the limit. I have to push it away from the switch manually at first, but than the axis have to be re-initialized.
Is it possible to re-enable the machine while the switch is pressed and than jog the axis away from it?
Thanks in advance!!
Thanks in advance!!
Last edit: 21 Jan 2015 21:28 by TopperH.
- ArcEye
- Thank you received: 758
21 Jan 2015 21:49 #55238
by ArcEye
Replied by ArcEye on topic Jog axis after limit switch reached
Hi
There is a checkbox with the label 'Override Limits' or similar on the 'Manual Control [F3]' tab
Tick it whilst everything is greyed out, then Press F2 and you can jog off the limit switch
The following user(s) said Thank You: fit2cnc
Time to create page: 0.226 seconds
