x,y axis angle problem
- alseusrah
03 Feb 2015 22:25 #55647
by alseusrah
x,y axis angle problem was created by alseusrah
Hi ,
I have problem with x,y axis angle ,my working table is 500x350mm but one axis have problem when i draw 90degree angle i have deviation about 7mm from start point (angle is bigger than 90 degree) ... is there any way to fix this in linux cnc config... thank you ,sorry for bad english.
- Thank you received: 4992
03 Feb 2015 23:15 #55650
Yes, you can use "millkins" instead of trivkins. This was written for just this situation.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...y_XY_skew_correction
Replied by andypugh on topic x,y axis angle problem
Hi ,
The following user(s) said Thank You: alseusrah
Time to create page: 0.063 seconds
