Gmoccapy + gantrykins
- Green#
23 Feb 2015 05:15 - 24 Feb 2015 08:01 #56224
by Green#
Gmoccapy + gantrykins was created by Green#
Hello,
I'm trying to move working axis configuration to gmoccapy GUI. There were several problems and messages at start but finally I was able to start linuxcnc without errors. After while I realized its impossible to control of any axises. Triggering it manually, or via home button didn't caused any move and position's values doesn't change. It took me some time but I find the problem is gantrykins, When I change it to trivkins, machine get alive, but oryginal config is based on gantrykins, it's plasma cutter, so it probably doesn't work good at trivial kins mode. Please help.
Is it possible to use gantrykins with gmoccapy gui?
Last edit: 24 Feb 2015 08:01 by Green#.
Time to create page: 0.044 seconds
