only x y without z
- albova
13 Mar 2015 14:50 - 13 Mar 2015 14:50 #56781
by albova
only x y without z was created by albova
hi
my machine has only two axes x and y
I would like to remove from LinuxCNC z-axis or possibly exclude commands PgUp and PgDn keyboard to prevent the following error of the z-axis
any solution?
Working with mesa m5i20 - 7i33 -7i37 and version 2.6.7 LinuxCNC
Ale
any solution?
Ale
Last edit: 13 Mar 2015 14:50 by albova.
- ArcEye
- Thank you received: 758
13 Mar 2015 22:14 - 13 Mar 2015 23:49 #56788
by ArcEye
Replied by ArcEye on topic only x y without z
Hi
You are into editing by hand.
It is quite simple, you just reduce the number of axes to 2, co-ordinates to X Y and remove all Z references and connections
I have edited a stepconf config to show the basis of it, yours will be a bit more complex because of the mesa boards, but the principle is the same
Last edit: 13 Mar 2015 23:49 by ArcEye.
Time to create page: 0.069 seconds
