gmoccapy startup error
- brosskgm
23 Mar 2015 19:35 - 23 Mar 2015 19:56 #57106
by brosskgm
gmoccapy startup error was created by brosskgm
Using Ubuntu 10.04
I'm just starting out, so I might be missing something. I just upgraded Linux CNC to 2.6.7 it created an extra directory linuxcnc-dev.
I'm using one of those 3020T China systems. I was finally able to get a config to operate it properly and even cut my first radiant piece.
I built a probe to set Z axis but realised I needed to upgrade LinuxCNC to use it.
After the upgrade there is not a gmoccapy selection under applications/CNC.
When I run gmoccapy from command lline I get the following error in a popup.
Found an error!
The following information may be useful in troubleshooting:
File "/usr/bin/gmoccapy", line 106, in <module>
from gmoccapy import getiniinfo # this handles the INI File reading so checking is done in that module
File "/usr/lib/pymodules/python2.6/gmoccapy/getiniinfo.py", line 30, in <module>
CONFIGPATH = os.environ
File "/usr/lib/python2.6/UserDict.py", line 22, in __getitem__
raise KeyError(key)
KeyError: 'CONFIG_DIR'
Thanks in advance for your help.
Bob
Found an error!
raise KeyError(key)
Bob
Last edit: 23 Mar 2015 19:56 by brosskgm.
- brosskgm
27 Mar 2015 21:08 #57233
by brosskgm
Replied by brosskgm on topic gmoccapy startup error
I guess no one has seen this before. All the views, but no one could help.
Thanks anyway.
Thanks anyway.
- backwoodsjack
05 May 2015 05:17 #58389
by backwoodsjack
Replied by backwoodsjack on topic gmoccapy startup error
Hi--
I was just on Ebay looking for a cheap cnc mill and saw those chicom 3020T for under 500 bucks..
just wondered what u think of them now.. i am just looking to cut wood parts to make wooden boxes..
thanks for any advice..
cheers
cheers
Time to create page: 0.057 seconds
