Estop & Spindle
- upa-de
03 Jul 2015 00:27 #60351
by upa-de
Replied by upa-de on topic Estop & Spindle
ok that did the trick, thanks a bunch!
Do you think that the e-stop or charge pump isn't configured correctly? Would that be why the spindle will run when the e stop isn't latched when linuxcnc isn't running? My solid state relay light is on when linuxcnc is off and the e-stop is up, for instance. when i am in linuxcnc the light is off untill i use the spindle.
- Thank you received: 5213
03 Jul 2015 22:52 #60386
Replied by PCW on topic Estop & Spindle
Is the charge pump enabled on the G540?
Is the stepgen used to run the chargepump enabled by machine-on?
Time to create page: 0.098 seconds
