No Gentrivkins module
- KenC
24 Apr 2015 17:35 #58076
by KenC
Replied by KenC on topic No Gentrivkins module
thanks for the ext2 format info, was using a FAT32
hunted down another USB stick and formatted to ext2.
copied the directories. /home & /etc
What next.
What next.
- ArcEye
- Thank you received: 758
24 Apr 2015 21:41 #58084
by ArcEye
Replied by ArcEye on topic No Gentrivkins module
You might as well try to remove the linuxcnc package and see if the other stuff you didn't want is removed as well, or is able to be removed.
Then you could just install the correct Lucid package and see how it goes.
If it does not work, nothing lost, just reinstall and re-instate your home dir.
Then you can track down what you did to get your screen to work, probably something in /etc/X11/xorg.conf.d, but might be elsewhere
- KenC
24 Apr 2015 21:59 #58085
by KenC
too late, before I can do anything, the horrid blue screen is in the house!!
Anyway, a last sanity check.
Does Debian runs with X11 ore Xorg?
because my touchscreen worked with Elotouch installation on Lucid
- ArcEye
24 Apr 2015 22:16 #58086
by ArcEye
I don't know what you mean, but if you are contemplating increasing complexity by 100% by now installing a completely different distro,
that you have no idea as to whether it will support your touchscreen, then don't .
Just reinstall Lucid, try to not format the partition as I described.
Lots of people have had problems with touchscreens under the debian distro, screens that worked OK under Lucid and even standard Debian,
so don't go down that route until there is something available only in Debian that will make all the hassle worth while.
The following user(s) said Thank You: KenC
- KenC
25 Apr 2015 08:53 - 25 Apr 2015 08:54 #58103
by KenC
I was really hesitant to use wheezy. all because of my touchscreen.
Just have to stick to Lucid.
Last edit: 25 Apr 2015 08:54 by KenC.
Time to create page: 0.188 seconds
