How to change default Jog speed
- cwebs
- Thank you received: 3
26 Apr 2015 02:48 #58128
by cwebs
How to change default Jog speed was created by cwebs
I have looked and can't seem to find what settings to change to have the default jog speed higher. Now Linuxcncn starts at 6 ipm and I always have to advance the slider to get a reasonable speed. Thanks for any help, Carl
- Thank you received: 2162
26 Apr 2015 08:26 #58130
Replied by cmorley on topic How to change default Jog speed
Are you using AXIS?
www.linuxcnc.org/docs/2.6/html/config/in...#sub:DISPLAY-section
Under the [DISPLAY] heading of the INI file:
DEFAULT_LINEAR_VELOCITY =
That would be in inches/mm per second
Chris M
Chris M
The following user(s) said Thank You: cwebs, thefabricator03
- cwebs
26 Apr 2015 17:45 #58133
by cwebs
Replied by cwebs on topic How to change default Jog speed
Thank you for the answer and link to the correct Docs. I looked for two hours yesterday and never found any thing to help. Carl
The following user(s) said Thank You: DarkPhoinix
Time to create page: 0.082 seconds
