difference PWMGEN fwd / rev
01 May 2015 23:34 #58301 by mpvriens
difference PWMGEN fwd / rev was created by mpvriens
Hello,
Have the mesa 7i48 installed, working fine, but when jogging forward i have a smooth motor movement, but when jogging backward, the signal is very unstable .
Also when watching the signal in the hal tree, you can see a stable pwmgen voltage jogging fwd, but a fluctuating voltage moving backwards.
Any suggestions ?
01 May 2015 23:48 - 01 May 2015 23:55 #58302 by PCW
Replied by PCW on topic difference PWMGEN fwd / rev
Yes, you must set the PWM mode to up/down for the 7I48
This is done by setting the pwmgen output_type parameter to 2
edit:
sorry thats output-type
Last edit: 01 May 2015 23:55 by PCW.
The following user(s) said Thank You: mpvriens
Time to create page: 0.079 seconds
