halrun
- pmcstoneinc
16 May 2015 02:20 #58752
by pmcstoneinc
halrun was created by pmcstoneinc
Just had a question about the following errors
halcmd: loadrt hm2_eth
Note: Using POSIX realtime
hm2_eth: dlopen: /usr/lib/linuxcnc/modules/hm2_eth.so: undefined symbol: hm2_register
<stdin>:1: waitpid failed /usr/bin/rtapi_app hm2_eth
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hm2_eth failed, returned -1
Also where can I find a startup config file for a 7i92 w/7i77. Thanks!
- Thank you received: 5263
16 May 2015 23:09 #58761
Replied by PCW on topic halrun
You need to load hostmot2 before the interface specific part of the driver, for example:
halcmd: loadrt hostmot2
halcmd loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 sserial_port_0=20xxxxxx"
(assuming you have the 7I92 jumpered to use the EEPROM IP address which defaults to 10.10.10.10)
You can use a 5i25/7i77 config and just change all the 5i25s to 7i92s
(and add the ip address token to the loadrt hm2_eth command line)
Time to create page: 0.054 seconds
