recovering from a on limit error?
- rotccapt
07 Jun 2015 22:05 #59582
by rotccapt
Replied by rotccapt on topic recovering from a on limit error?
i have 3 pins for my limits one for each axis, i have two switches per axis wired in series. when i run step config i have "home + max limit" selected for each axis. i know that the y axis is still not working i have not tested the x since it is a bit hard to get to.
- BigJohnT
- Thank you received: 1176
07 Jun 2015 22:28 #59589
by BigJohnT
Replied by BigJohnT on topic recovering from a on limit error?
The correct selection for that scenario is Both Limit + Home X
JT
JT
- rotccapt
07 Jun 2015 23:10 - 07 Jun 2015 23:11 #59594
by rotccapt
i had a feeling that was what i was supposed to use. i will make that change.
again thank you for your help
Last edit: 07 Jun 2015 23:11 by rotccapt.
Time to create page: 0.061 seconds
