connection -> gmoccapy to THC
- ZX-Sinclair
18 Aug 2015 09:40 - 18 Aug 2015 16:43 #61502
by ZX-Sinclair
Replied by ZX-Sinclair on topic connection -> gmoccapy to THC
I know the link to the manpage.
It's only a short description.
Are there any further informations?
If i insert in the .hal
loadrt thcud
and
thc.torch-up <= paraport.0.pin-15-in
Error message: thc.torch-up
Update:
This sentence:
thc.torch-up <= paraport.0.pin-12-in thc.torch-down <= paraport.0.pin-13-in motion.spindle-on => parport.0.pin-16-out (start the arc) thc.arc-ok <= motion.digital-in-00 <= parport.0.pin-15-in
from manpage means:
net thc.torch-up <= parport.0.pin-15-in
net thc.torch-down <= parport.0.pin-10-in
net thc.requested-vel <= motion.requested-vel
net thc.current-vel <= motion.current-vel
Next error: the name is parport, NOT paraport
And so on. At the moment it works, but always without Up/Down
loadrt thcud
and
Update:
This sentence:
from manpage means:
Last edit: 18 Aug 2015 16:43 by ZX-Sinclair.
- cncbasher
- Thank you received: 288
18 Aug 2015 16:49 - 18 Aug 2015 16:58 #61503
by cncbasher
typo should be
parport.0.pin-12-in thc.torch-down <= parport.0.pin-13-in
Replied by cncbasher on topic connection -> gmoccapy to THC
loadrt thcud
and
Update:
This sentence:
from manpage means:
typo should be
Last edit: 18 Aug 2015 16:58 by cncbasher.
- BigJohnT
- Thank you received: 1176
18 Aug 2015 18:55 #61504
by BigJohnT
The man page is all the documentation for the thcud component and is quite elaborate compared to most man pages.
Lets start at the top:
First you have to load the component in your hal file with:
Next in Axis (I don't know about other GUI's) run Show Hal Configuration and see what the name of the thcud function is. Then you have to 'add' the thcud component to a thread so it will actual do something with:
Next looking in Show Hal Configuration Pins find the exact name of the pins you wish to connect to and using the net command and a signal name connect them.
Please read about the net command here:
www.linuxcnc.org/docs/2.7/html/hal/basic-hal.html
JT
Replied by BigJohnT on topic connection -> gmoccapy to THC
loadrt thcud
and
loadrt thcud
addf thcud base-thread
net torch-up thcud.torch-up <= paraport.0.pin-12-in
JT
- ZX-Sinclair
18 Aug 2015 19:37 - 18 Aug 2015 19:38 #61505
by ZX-Sinclair
Ah, ok!
I have the same HalShow than in axis.
If i select "functions", there is a lot of stuff and "thcud".
And selected:
after i inserted in my hal:i get the error message:
What does that mean? FP is YES
And selected:
owner 12
CodeAddr f8ff0000
Argf8ff8
FP yes
users 0
name thcud
error ; function 'thcud' needs FP
Last edit: 18 Aug 2015 19:38 by ZX-Sinclair.
- Thank you received: 1467
18 Aug 2015 20:38 #61508
Replied by Todd Zuercher on topic connection -> gmoccapy to THC
It means that it needs to be in a floating point thread (such as the servo-thread), and the base-thread you have it in is non-floating point. it is possible to configure the base thread to support a floating point.
see: linuxcnc.org/docs/html/man/man9/motion.9.html
You will need to find base_thread_fp=0 and change it to base_thread_fp=1 (or add it if it does not exist.)
- ZX-Sinclair
19 Aug 2015 01:42 #61524
by ZX-Sinclair
I think i'm to stupid for that.
Since two weeks the machine is ready and has to run.
It is cheaper if a specialist flies from USA and adjusts the parameters.
And i understand nothing.
I have searched in all files.
"base_thread_fp=0" doesn't exist
So i have added this
"base_thread_fp=1" in the .hal
- error: unknown command
with the addf in front:
- error: addf needs 2 args
- BigJohnT
19 Aug 2015 01:46 #61525
by BigJohnT
Just leave the base-thread alone and add the function to the servo-thread.
JT
JT
- ZX-Sinclair
19 Aug 2015 02:09 #61526
by ZX-Sinclair
I'm confused...
what means:
"leave the base-thread alone"?
addf thcud base-thread (=error)
thcud base-thread (=error unknown command)
and which part is the servo thread?
iIn my HAL are things like:
"addf stepgen.capture-position servo-thread"
Is that the servo-thread?
Should i insert "addf thcud base-thread" behind that part or "base_thread_fp=1 "
what means:
- BigJohnT
19 Aug 2015 02:19 #61528
by BigJohnT
That means don't change the base thread to floating point as Todd suggested. You can't just guess what to put in the hal file it only supports a few commands like net, addf, sets, setp and they have specific format.
If the thcud component uses FP (Floating Point) then add it to the servo thread just like other functions have been added to the servo thread. It's my fault I assumed the thcud was not using FP so I told you wrong.
This should get the component up and running then you have to use the net command to connect the pins.
JT
loadrt thcud
addf thcud servo-thread
JT
- ZX-Sinclair
19 Aug 2015 17:26 #61545
by ZX-Sinclair
Ok,
i inserted "addf thcud servo-thread" in my HAL
No error during start up, but my signals and plasma panel is away!
I know that effect.
This is my "Signals.HAL":If i remove one # i have the same effect.
I know that effect.
# Hook up signal pins connecting
# Out pin
#net MoveDown => signals.led_MoveDown
#net MoveUp => signals.led_MoveUp
#net FloatSwitch => signals.led_FloatSwitch
#net ArcOK => signals.led_ArcOK
#net TorchOn => signals.led_TorchOn
#net HeightLock => signals.led_HeightLock
