Tool Length Offset
03 Sep 2015 03:19 #62072 by BigJohnT
Replied by BigJohnT on topic Tool Length Offset
In the HalConfiguration i can watch pins during cutting:
- torch-up
- torch-down
- touch
- ok
This are the four hardware pins from the THC electronic module.
The signal thcud "arc-ok" doesn't work...
Also all other values for Z-positioning.
What does arc ok not do?
What do you mean by "Also all other values for Z-positioning"? This statement makes no sense to me.
Before the thcud component will apply an offset to the Z axis these conditions must be met:
thcud enable must be on
thcud arc_ok must be on
actual velocity must be within the tolerance set by you to requested velocity
Any of the above conditions not met and the thcud does nothing.
JT
06 Sep 2015 19:40 - 06 Sep 2015 19:51 #62166 by ZX-Sinclair
Replied by ZX-Sinclair on topic Tool Length Offset
Nothing. Also if the arc is "OK".
For me the sense is that the THCUD controls the z axis.
But all the z-values (z-pos. Z-fb) are static.
I suppose that there is a mismatch in velocity?
I don't exactely know how to adjust. I didn't find any informations.
The request-vel is 30
current-vel i adjust between 25 and 35 (without any changes)
correction-vel 0
z-pos-in and out 0
Does anybody know something about the thcud velocity?
Last edit: 06 Sep 2015 19:51 by ZX-Sinclair.
06 Sep 2015 21:29 #62169 by PCW
Replied by PCW on topic Tool Length Offset
You need to set the correction velocity to a reasonable value
This a a thcud parameter: thcud.correction-vel
Did you read the thcud manual page?
06 Sep 2015 21:30 #62170 by cncbasher
Replied by cncbasher on topic Tool Length Offset
when cutting and a plasma cut is being performed , this signal pin should go on , or change state does it ?
Time to create page: 0.065 seconds
