using a hand wheel encoder
09 Jan 2016 15:41 #68131 by bobobo
Replied by bobobo on topic using a hand wheel encoder
hm2_7i80.0.7i84.0.1.enc0.count changes according to rotation of the handwheel.
09 Jan 2016 15:49 - 09 Jan 2016 15:53 #68132 by PCW
Replied by PCW on topic using a hand wheel encoder
OK I will try and duplicate this here on Monday
Could be a setsserial bug or 7I84 bug
(if the mean time, if you have free high speed encoder that will do 4x mode)
Last edit: 09 Jan 2016 15:53 by PCW.
09 Jan 2016 15:53 #68133 by bobobo
Ok, thanks for your support.
BTW when using the setsserial it ended with "Parameter successfully set" (I don't remember exact wording)
12 Jan 2016 22:18 #68284 by PCW
OK, I found the bug (its a 7I84 and 7I77 firmware bug):
The nvencoder_modeN parameters are not copied to the
volatile parameters (encodermodeN) at startup
it does work in the 7I76
I will fix the 7I84 and 7I77 firmware when I get a chance
27 Feb 2016 18:25 - 27 Feb 2016 18:37 #70736 by Sparky961
Replied by Sparky961 on topic using a hand wheel encoder
What are the chances you've fixed this? I'm having the same issue.
I will have a free high speed encoder with my planned configuration, but its still annoying.
***EDIT***
I neglected to power cycle the board after reading this, thinking that I needn't bother. Turns out it must have been fixed in the firmware for my recent board. Disregard.
***EDIT***
Last edit: 27 Feb 2016 18:37 by Sparky961. Reason: Corrected
10 Mar 2016 11:38 #71348 by PCW
freeby.mesanet.com/sserial.tgz
Has updated firmware files that fix the nvencoder bug in the 7I84 (and 7I69)
Time to create page: 0.487 seconds
