Correct Z limit swith syntax for hal
- allenwg2005
- Thank you received: 4
14 Sep 2015 05:03 #62525
by allenwg2005
Correct Z limit swith syntax for hal was created by allenwg2005
I have a new (to me) PC with the latest 2.7.0 installed.
Everything works with the exception of the Z axis home limit.
I have tested it with the ptest utility and I can trigger my Z home proximity and the green #10 pin goes red.
My hal read: net min-home-z <= parport.1.pin-10-in-not
Changed it to: net min-home-z <= parport.1.pin-10-in
It didn't help, can someone please set me straight here.
- cncbasher
- Thank you received: 288
14 Sep 2015 16:29 #62551
by cncbasher
Replied by cncbasher on topic Correct Z limit swith syntax for hal
all i see is a probable mixup
you have min & home tied to z , thats unusual as it would really mean your head would be crashing into the table when homing
so i believe home should be at max z
hope that helps Allen
Time to create page: 0.044 seconds
