keystroke as a hal pin?
- jtc
- Thank you received: 12
01 Oct 2015 14:12 #63325
by jtc
keystroke as a hal pin? was created by jtc
I'm wondering if is possible to assign a keyboard keystroke as an HAL pin? My objective is to use 3 keys, witch one will call a subroutine.
the first will open a log file, the second to log the X and Y coordinates, and finally the third to close the log file. If I can use this with the present keyboard keys it will be great.
- Thank you received: 2182
01 Oct 2015 14:32 #63326
Replied by cmorley on topic keystroke as a hal pin?
What screen are you using?
Gmoccapy or Gscreen are easier to add this to then AXIS
Chris M
Chris M
- jtc
01 Oct 2015 14:36 #63327
by jtc
Replied by jtc on topic keystroke as a hal pin?
I'm using Axis screen.
I prefer a solution that don't depends on the screen. The machine has already a custom panel on axis, and do the complete migration will involve some work...
01 Oct 2015 14:55 #63329
The solution will always depend on the screen, if you wish to use the standard keyboard.
If you wish to use some other external buttons then it can be outside of the running screen.
That being said it is not impossible with AXIS it's just not many people know it well enough - including me.
Chris M
Chris M
- jtc
02 Oct 2015 00:10 #63352
by jtc
with thios post help :
www.linuxcnc.org/index.php/english/forum...gging?start=10#62208
and seeing the axis.py file
I add to my ini file configuration on the display area:
and the keystroke.py contains this code:
so, at this point, if I have some mdi command on the "buffer"
but I cant find any "commands.send_mdi" that have a string as an argument. or a way to write on the "buffer".
João
[DISPLAY]
USER_COMMAND_FILE = keystroke.pyand the keystroke.py contains this code:
root_window.bind("<KeyPress-j>",commands.send_mdi )so, at this point, if I have some mdi command on the "buffer"
João
- Thank you received: 4660
06 Oct 2015 14:33 #63490
Does this help?
www.linuxcnc.org/docs/html/config/python-interface.html
Replied by andypugh on topic keystroke as a hal pin?
Does this help?
- jtc
06 Oct 2015 21:14 - 06 Oct 2015 21:18 #63514
by jtc
I already had seen this link, I tryed to use the following code on my .py file:
hopping to see to be executed on simulation, but without success.
regarding the original idea of the topic, using a keystroke as an hal pin, in axis.py file, next to line 3226 I find this:
that create the axisui pins, but if I changed the name of one of these pins, when start linuxcnc I can´t see any difference in axisui pin names.
So, I'm missing something...
João
Does this help?
import linuxcnc
s = linuxcnc.stat()
c = linuxcnc.command()
def ok_for_mdi():
s.poll()
return not s.estop and s.enabled and s.homed and (s.interp_state == linuxcnc.INTERP_IDLE)
if ok_for_mdi():
c.mode(linuxcnc.MODE_MDI)
c.wait_complete() # wait until mode switch executed
c.mdi("G0 X10 Y20 Z30")hopping to see to be executed on simulation, but without success.
if hal_present == 1 :
comp = hal.component("axisui")
comp.newpin("jog.x", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.y", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.z", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.a", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.b", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.c", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.u", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.v", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.w", hal.HAL_BIT, hal.HAL_OUT)
comp.newpin("jog.increment", hal.HAL_FLOAT, hal.HAL_OUT)
comp.newpin("notifications-clear",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("notifications-clear-info",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("notifications-clear-error",hal.HAL_BIT,hal.HAL_IN)
comp.newpin("resume-inhibit",hal.HAL_BIT,hal.HAL_IN)that create the axisui pins, but if I changed the name of one of these pins, when start linuxcnc I can´t see any difference in axisui pin names.
João
Last edit: 06 Oct 2015 21:18 by jtc.
07 Oct 2015 00:33 #63522
That ought to work, it normally does.
if ok_for_mdi():
c.mdi("G0 X10 Y20 Z30")[/code]
- ArcEye
- Thank you received: 240
07 Oct 2015 11:29 #63531
by ArcEye
It is already available as standard in Machinekit, with modifications I added some while ago.
You can assign 10 commands, MDI, HAL or system to the 0 - 9 number keys
See mgware.co.uk/ > Axis Modifications > User Defined Commands to read the details and download the zip.
I have not bothered keeping it current with Linuxcnc versions, but the code should be pretty much unchanged.
Replied by ArcEye on topic keystroke as a hal pin?
- jtc
07 Oct 2015 14:04 #63537
by jtc
I will see it.
Time to create page: 0.204 seconds
