Debian jessie + Mesa 7i76E
  • jtc
  • jtc's Avatar Topic Author
  • Premium Member
  • Premium Member
03 Nov 2015 23:37 #64736 by jtc
Debian jessie + Mesa 7i76E was created by jtc
Hi!
My plans is to upgrade to debian jessie, and use Mesa 7i76E boards for a new machine configuration. So I make this post in advance to see if I'm making something wrong and save some time.
For what I search, on this topic: linuxcnc.org/index.php/english/forum/9-i...d-mesa-ethernet-card, mesa ethernet cards need a Preempt kernel, and linuxcnc-uspace, my question is what is the differences between linuxcnc-uspace and the "normal" LCNC?
I find this instructions, linuxcnc.org/docs/2.7/html/getting-start...th_preempt_rt_kernel, so I hope its just install like is described, but and if I want to install in a RunInPlace configuration? there is a specific branch?
Any advices will be welcome.
João
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
04 Nov 2015 01:26 - 04 Nov 2015 01:30 #64737 by andypugh
Replied by andypugh on topic Debian jessie + Mesa 7i76E
No, you just run configure with --with-realtime=uspace (or let it self-discover what brand of realtime system you have)
Last edit: 04 Nov 2015 01:30 by andypugh.
04 Nov 2015 09:29 #64739 by ArcEye
Replied by ArcEye on topic Debian jessie + Mesa 7i76E
The guide covers it, but just to emphasise it.
Jessie does not have a stock rt-preempt kernel. Their kernel maintainer was supposed to be introducing one, but it has not happened yet.
I was not aware there was a backport, but that should work.
The alternative is to build your own, this thread has a link to the docs and some other info
sourceforge.net/p/emc/mailman/message/33665819/
www.linuxcnc.org/index.php/english/forum...-14041-linuxcnc-help
The following user(s) said Thank You: jtc
  • jtc
  • Premium Member
  • Premium Member
06 Nov 2015 23:28 #64931 by jtc
Replied by jtc on topic Debian jessie + Mesa 7i76E
I'm not comfortable to build a build a kernel, so looks like I will compile the RunInPlace version to use uspace.
Regarding the mesa 7i76E, I should use a straight Ethernet cable? I searched for this information but didn't find anything.
João
07 Nov 2015 00:46 #64934 by PCW
Replied by PCW on topic Debian jessie + Mesa 7i76E
Any Ethernet cable will do (straight through or crossover)
The PHY on the 7I76E has whats called MDIX which means it figures out
if the TX/RX pairs are swapped and swaps them internally if it needs to
  • jtc
  • Premium Member
  • Premium Member
11 Nov 2015 12:15 #65131 by jtc
I have make a new debian installation on another pc . already intall the rt kernel, but when try this command:
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 8f374fef
I got his message:
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /tmp/tmp.cGAkwK5HjW --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-security-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-stable.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-squeeze-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-squeeze-stable.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-wheezy-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-wheezy-stable.gpg --keyserver hkp://keys.gnupg.net --recv-key 8f374fef
gpg: requesting key 8F374FEF from hkp server keys.gnupg.net
?: keys.gnupg.net: Host not found
gpgkeys: HTTP fetch error 7: couldn't connect: No such file or directory
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
Host not found... any clue how to solve it?
João
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
11 Nov 2015 18:12 #65152 by andypugh
If you google for "keys.gnupg.net: Host not found" then a number of possibilities will be presented.
It looks like the trick is to use a different key server.
(This actually has nothing much to do with LinuxCNC)
  • jtc
  • Premium Member
  • Premium Member
12 Nov 2015 12:51 - 12 Nov 2015 12:52 #65176 by jtc
changing the host to the ip adress solve the problem.
now, another problems...
I create a new configuration with Pncconf and configure manually the ip adress of the pc.
I can ping the board:
jtc@jtctech:~/linuxcnc/configs/mesa7i76e$ ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_req=1 ttl=64 time=0.126 ms
64 bytes from 192.168.1.121: icmp_req=2 ttl=64 time=0.115 ms
64 bytes from 192.168.1.121: icmp_req=3 ttl=64 time=0.117 ms
64 bytes from 192.168.1.121: icmp_req=4 ttl=64 time=0.118 ms
64 bytes from 192.168.1.121: icmp_req=5 ttl=64 time=0.119 ms
64 bytes from 192.168.1.121: icmp_req=6 ttl=64 time=0.117 ms
64 bytes from 192.168.1.121: icmp_req=7 ttl=64 time=0.119 ms
64 bytes from 192.168.1.121: icmp_req=8 ttl=64 time=0.117 ms
^C
--- 192.168.1.121 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 6998ms
rtt min/avg/max/mdev = 0.115/0.118/0.126/0.011 ms
when try to run the configuration:
Machine configuration directory is '/home/jtc/linuxcnc/configs/mesa7i76e'
Machine configuration file is 'mesa7i76e.ini'
Starting LinuxCNC...
Found file(REL): ./mesa7i76e.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:10:40:1d
hm2_eth: Unrecognized ethernet board found: ���������������� -- port names will be wrong
hm2_eth: discovered ����������������
hm2: invalid llio name passed in (contains non-printable character)
board fails HM2 registration
hm2_eth: rtapi_app_main: Invalid argument (-22)
./mesa7i76e.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./mesa7i76e.hal:8: /usr/bin/rtapi_app exited without becoming ready
./mesa7i76e.hal:8: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/jtc/linuxcnc_debug.txt
and
    /home/jtc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
I suspected that the board had the wrong firmware, but when try to verify:
jtc@jtctech:~/Downloads/firmware$ mesaflash --device 7i76e --verify 7I76R14.BIN Unsupported ethernet device ���������������� at 192.168.1.121
No 7I76E board found
João
Last edit: 12 Nov 2015 12:52 by jtc.
  • jtc
  • Premium Member
  • Premium Member
13 Nov 2015 07:04 #65200 by jtc
last day I spend 2 our 3 hours try to find the solution but without success. the only information closer that I can find is in the this thread:
forum.linuxcnc.org/forum/27-driver-board...80-and-7i77?start=70
but nothing like this problem.
this is my network settings:
jtc@jtctech:~$ sudo /sbin/ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:0b:cd:e2:6f:ef
          inet addr:192.168.1.120  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::20b:cdff:fee2:6fef/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:45 errors:0 dropped:0 overruns:0 frame:0
          TX packets:210 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4136 (4.0 KiB)  TX bytes:25452 (24.8 KiB)
          Interrupt:20
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:288 errors:0 dropped:0 overruns:0 frame:0
          TX packets:288 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:25894 (25.2 KiB)  TX bytes:25894 (25.2 KiB)
wlan0     Link encap:Ethernet  HWaddr 30:b5:c2:17:31:ac
          inet6 addr: fe80::32b5:c2ff:fe17:31ac/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500 Metric:1
          RX packets:5351 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3462 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4056544 (3.8 MiB)  TX bytes:533629 (521.1 KiB)
jtc@jtctech:~$
João
Time to create page: 1.322 seconds
