Figured out the PCI to Parallel port card address
31 Dec 2015 11:02 #67604 by Jake
I thought I would share it so if someone else runs into it.
I did not know how to get the address set for the Pico PPMC to see where the card is.
In the command line lspci -v
This will show you where the cards address is as long as the computer is seeing it
there will be a line that says
I/O ports at ea00 the (ea00) is the address that will be different based on your machine
In the config file ppmc_load.hal
find line loadrt hal_ppmc
Add port_addr=0x(your address) to that line.
Done deal!
Thanks ArcEye and Jon for the help!
Jake
31 Dec 2015 11:05 #67605 by ArcEye
Possibly a bit late for you, but may help someone else.
There is a FAQ on that subject
forum.linuxcnc.org/forum/18-computer/189...-parallel-port-cards
31 Dec 2015 12:28 #67612 by jepler
In modern versions of linuxcnc where the Linux parallel port driver has not been disabled, you can simply use numbers from 0 to 15 to indicate the parallel ports in the order they are detected by Linux, as documented here: linuxcnc.org/docs/2.7/html/hal/parallel-port.html#_loading
While that documentation above is about the dumb parport driver, it should apply to Pico and Mesa parallel cards as well, because they use the same C API, hal_parport_get. If they don't, it's a bug that ought to be reported and addressed. (I certainly haven't tested this with any pico cards, because I don't own any, but I'm 95% certain I tested it with one of 7i43 or 7i90 after writing it)
It would also be ideal if somebody prepared a patch for ppmc, 7i43 and 7i90 docs in the linuxcnc source tree to make it clear that this style works there too, or at least updated the FAQ. I think a lot of people spend time trying to read lspci output like tea leaves, and it really shouldn't be necessary any longer for most users in new installs.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
31 Dec 2015 19:07 #67634 by andypugh
My Lathe uses a 7i43. It actually has nothing at all to tell it the Parport address:
loadrt hostmot2
loadrt hm2_7i43 config="firmware=hm2/7i43-4/SVST4_4.BIT num_encoders=2 num_pwmgens=1 num_stepgens=4 enable_raw"
It just works.
Time to create page: 0.495 seconds
