Difference between USER_M_PATH and nc_files path
- nicokid
- Thank you received: 3
23 Feb 2016 18:15 #70546
by nicokid
Difference between USER_M_PATH and nc_files path was created by nicokid
What is the difference in the use of a path in USER_M_PATH than the nc_files standard path?
In both I can specify user defined functions (M100-M199), is it right? Or these directories are used to do different things?
Nicola.
Nicola.
25 Feb 2016 07:30 #70614
Replied by andypugh on topic Difference between USER_M_PATH and nc_files path
You can use both. The idea is that you can keep your M-code subroutines somewhere out of the way where they are safe from over-zealous tidying-up.
- dgarrett
- Thank you received: 297
25 Feb 2016 09:23 #70623
by dgarrett
Replied by dgarrett on topic Difference between USER_M_PATH and nc_files path
Note that USER_M_PATH specifies a _list_ of directories that are searched
for executable files with names like M1xx.
Ref: linuxcnc.org/docs/2.7/html/config/ini-config.html
The 'nc_files' mentioned is a bit confusing.
The search list begins at [DISPLAY]PROGRAM_PREFIX which is conventionally set
to the directory ~/linuxcnc/nc_files by programs like pncconf and stepconf or
when a configuration is copied to a user directory using the config picker.
These programs typically create this directory if it does not exist.
The seldom-used 'default location: nc_files' specifies a subdirectory named
'nc_files' in the configuration directory that contains ini file. This
subdirectory must exist to be usable in the path search.
USER_M_PATH = myfuncs:/tmp/mcodes:experimentalmcodes - Specifies a list of colon (:) separated directories for user defined functions. Directories are specified relative to the current directory for the ini file or as absolute paths. The list must contain no intervening whitespace.
A search is made for each possible user defined function, typically (M100-M199). The search order is:
[DISPLAY]PROGRAM_PREFIX (if specified)
If [DISPLAY]PROGRAM_PREFIX is not specified, search the default location: nc_files
Then search each directory in the list [RS274NGC]USER_M_PATH
The first executable M1xx found in the search is used for each M1xx.The 'nc_files' mentioned is a bit confusing.
- nicokid
25 Feb 2016 09:46 #70625
by nicokid
Replied by nicokid on topic Difference between USER_M_PATH and nc_files path
As you know I have changed stepconf to add the configuration interface for the HALUI section of the ini file. Eventually I would like to fully configure my cnc machine 'stepcraft 840' using only stepconf. So I need to add even 'USER_M_PATH' under RS274NGC section in accordance with the specifications in this forum: www.stepcraft-systems.com/forum/software...allation-einrichtung. Another issue is the use of HALFILE and POSTGUI_HALFILE, but I check this later :) .
So you think is best to use USER_M_PATH for custom commands?
Nicola.
Nicola.
- nicokid
25 Feb 2016 17:29 #70647
by nicokid
Ok this is clear.
This is for me more confused than before.
The ini file is under ~/linuxcnc/configs not under ~/linuxcnc/nc_files. I do not understand.
Nicola.
Ok this is clear.
Nicola.
26 Feb 2016 05:00 #70666
What Dewey is saying (as I read it) is that there is a default location that is searched second:
~/linuxcnc/configs/my_config/nc_files
This is where you can put config-specific M-files, if you wish to.
- nicokid
26 Feb 2016 05:42 #70668
by nicokid
Uhmm... indeed my own USER_M_PATH path points to ~/linuxcnc/configs/stepcraft-840/mcode.
So if I change the name of directory mcode in nc_files I can avoid setting the USER_M_PATH parameter in .ini file?
Thanks, Nicola.
Thanks, Nicola.
26 Feb 2016 05:46 #70669
That is the way I read what Dewey posted. It is a simple experiment to find out
The following user(s) said Thank You: nicokid
- nicokid
26 Feb 2016 11:33 #70678
by nicokid
I did some tests
This does not work:
I can put my files with M codes (like M100) in this directory:that can be changed by setting PROGRAM_PREFIX parameters.
or
I can setting USER_M_PATH parameter, for example:
USER_M_PATH = nc_files
Then I can put my M files under:
In the end I think that the directory ~/linuxcnc /nc_files is for all ini configuration, while the directory specified by USER_M_PATH is just for one ini configuration (~/linuxcnc/configs/my_config/nc_files).
Nicola.
This does not work:
~/linuxcnc/nc_filesor
~/linuxcnc/configs/my_config/nc_filesIn the end I think that the directory ~/linuxcnc /nc_files is for all ini configuration, while the directory specified by USER_M_PATH is just for one ini configuration (~/linuxcnc/configs/my_config/nc_files).
Nicola.
- dgarrett
26 Feb 2016 18:40 - 26 Feb 2016 18:42 #70693
by dgarrett
The attached demo illustrates USER_M_PATH usage.
The config directory is named 'demo'.
The config directory also contains subdirectories named
d1,d2,d3, and nc_files.
The two included ini files (demo1.ini, demo2.ini) use a minimal
axis gui simulation configuration to access a simple gcode starup
file named demo.ngc
The demo1.ini config specifies:
The demo2.ini config removes (comments out) the PROGRAM_PREFIX:
Each subdirectory contains simple M1NN files to
identify their usage by encoding the value of the
motion.analog-in-00 pin which is read in the gcode file
named demo.ngc using the m66 cmd which populates the
variable #5399
To try:
file named demo.ngc
[DISPLAY]
PROGRAM_PREFIX = ./d1
[RS274NGC]
USER_M_PATH= ./d2:./d3:./nc_files
...The demo2.ini config removes (comments out) the PROGRAM_PREFIX:
[DISPLAY]
#PROGRAM_PREFIX=./d1
[RS274NGC]
...Each subdirectory contains simple M1NN files to
variable #5399
$ cat d1/M111
#!/bin/bash
halcmd setp motion.analog-in-00 1.111 # 1.xxx for dir d1
$ cat d2/M111
#!/bin/bash
halcmd setp motion.analog-in-00 2.111 # 2.xxx for dir d2
# ... etc.
$ cat nc_files/M111
#!/bin/bash
halcmd setp motion.analog-in-00 0.111 # 0.xxx for dir nc_files
[code]
Note that there are several files with the same name to
illustrate how the search works:
[code]
├── d1
│ └── M111
├── d2
│ ├── M111
│ └── M112
├── d3
│ ├── M111
│ ├── M112
│ └── M113
├── nc_files
└── M111To try:
mkdir /tmp/demo # make a test directory
cd /tmp/demo # work in that directory
wget https://forum.linuxcnc.org/media/kunena/attachments/512/mpath_demo.zip
unzip mpath_demo.zip # extract archive
linuxcnc demo1.ini & # try demo1
# F1 (clear Estop)
# F2 (machine On)
# R (run included program named demo.ngc)
# menu/Exit
linuxcnc demo2.ini & # repeat for demo2
Last edit: 26 Feb 2016 18:42 by dgarrett.
Time to create page: 0.709 seconds
