Homing switch recommendations
- gizmo6023
24 Feb 2016 13:28 - 24 Feb 2016 20:18 #70582
by gizmo6023
Homing switch recommendations was created by gizmo6023
I am just getting my machine set up and am looking for suggestions on good switches to use for homing.
I would like not to spend more than $25 each for a 3 axis machine (ShopFox M1110 with CNCFusion kit 1)
Regards,
Dave
Regards,
Dave
Last edit: 24 Feb 2016 20:18 by gizmo6023.
- kornphlake79
- Thank you received: 10
24 Feb 2016 20:46 - 24 Feb 2016 20:48 #70596
by kornphlake79
Replied by kornphlake79 on topic Homing switch recommendations
Omron makes good limit switches, but they are outside your budget. Automation direct sells some decent looking switches www.automationdirect.com/static/specs/limitaap.pdf
I've been happy with most items I've purchased from automationdirect.com, typically their products compete with products costing 3-4 times more.
Last edit: 24 Feb 2016 20:48 by kornphlake79.
The following user(s) said Thank You: gizmo6023
- gizmo6023
24 Feb 2016 22:21 #70599
by gizmo6023
Replied by gizmo6023 on topic Homing switch recommendations
Thank you, I will check their site out.
- BigJohnT
- Thank you received: 994
25 Feb 2016 08:53 #70620
by BigJohnT
Replied by BigJohnT on topic Homing switch recommendations
+1 for Automation Direct, been using them since they first started.
JT
JT
25 Feb 2016 16:59 #70645
I use $4 inductive proximity switches from China (NPN. Shielded, M8 size) and then enable index-homing to get the accuracy.
The latter part might not be an option with steppers, though a second prox on a cam on the motor shaft would help.
Replied by andypugh on topic Homing switch recommendations
Time to create page: 0.241 seconds
