No Jog without homing
11 Mar 2016 16:06 #71453 by verdi
No Jog without homing was created by verdi
Hi
i want to forbid manual jog before the machine is homed.
is there any solution to achieve that?
greets
verdi
12 Mar 2016 14:19 #71501 by cmorley
Replied by cmorley on topic No Jog without homing
Yes.
in the INI file, under the [TRAJ] heading change:
NO_FORCE_HOMING = 1
to 0
Chris M
12 Mar 2016 14:31 #71503 by BigJohnT
Replied by BigJohnT on topic No Jog without homing
Hi Chris,
He want to not allow jogging before homing.
NO_FORCE_HOMING = 1 - The default behavior is for LinuxCNC to force the user to home the machine before any MDI command or a program is run. Normally, only jogging is allowed before homing. Setting NO_FORCE_HOMING = 1 allows the user to make MDI moves and run programs without homing the machine first. Interfaces without homing ability will need to have this option set to 1.
JT
12 Mar 2016 14:52 - 12 Mar 2016 14:53 #71504 by cmorley
John ...very sure I'm correct.
having no_force_homing TRUE makes it NOT force homing.
Setting it to FALSE makes it force homing.
I said to change it to zero, which is false
Either way he now know what to change :)
Last edit: 12 Mar 2016 14:53 by cmorley.
12 Mar 2016 15:17 #71506 by verdi
Replied by verdi on topic No Jog without homing
hi
it is already working that you cant put in manual gcode or ran a program without homing.
but i also want to forbid jog before homing!
12 Mar 2016 17:23 #71528 by cmorley
lol you are right of course - i should read the docs too!
i was sure you could do this
What screen are you using?
A quick look says there is no easy way to do this - it would require to customise the screen code a bit.
gscreen or Gmoccapy is easiest to modify.
or if you don't use a keyboard (so one one can keyboard jog) you could do it in with HAL code.
Chris m
12 Mar 2016 17:36 - 12 Mar 2016 17:38 #71529 by cmorley
I thought of a way to do this easier.
In 2.7 there is a pin: motion.feed-inhibit
set it true and no movement will occur but with a happy strangeness homing will still work!
Homing is completely different from any other movement.
so maybe you could connect it to HALUI's halui.joint.<n>.is-homed or axis.N.homed
Chris M
Last edit: 12 Mar 2016 17:38 by cmorley.
The following user(s) said Thank You: BigJohnT
Time to create page: 0.272 seconds
