Help with homing mesa 7i76
  • Clive S
  • Platinum Member
  • Platinum Member
13 Mar 2016 04:08 #71546 by Clive S
Help with homing mesa 7i76 was created by Clive S
I have 3 home switches on my mill and they appear to work OK. I would like to change the HAL and or INI files to make them do home with min limit for x and y and home with max limit for z.
I have setup soft limits for all axis. I have tried to do this with PnCConf but it seems very buggy. What changes to the ini and hal files do I need to change
File Name: Warco_mill.zip
File Size:5 KB
13 Mar 2016 08:36 #71560 by BigJohnT
  • Clive S
  • Platinum Member
  • Platinum Member
13 Mar 2016 08:46 #71562 by Clive S
Replied by Clive S on topic Help with homing mesa 7i76
linuxcnc.org/docs/2.7/html/config/ini-homing.html
JT
John thanks. I have read that many times and I have the mill homing ok but just setup as home But I want to set up as home + min_limit.
It is the modifications in the HAL and INI files I need to achieve this
15 Mar 2016 16:56 #71700 by BigJohnT
Replied by BigJohnT on topic Help with homing mesa 7i76
I'm not really sure what your wanting to do but it sounds like you want to have the home position off the switch by a small amount? The easiest way would be to change your ini settings. If that is correct then you need to set your HOME_OFFSET for the axis.
JT
  • Clive S
  • Platinum Member
  • Platinum Member
15 Mar 2016 18:31 #71704 by Clive S
JT
What I am trying to achieve is I want to use the same switch for homing and min limit. ie shared I had this working before using the pp. But now I have a 5i25 + 7176 comb and using PnCConf. But PnCConf has a bug in it that does not allow me to setup up shared homing etc.
I am asking for some sample lines of code (say for the X axis) that I need to add to the HAL file to change it from homing to shared with min limit.
15 Mar 2016 18:38 - 15 Mar 2016 18:39 #71705 by BigJohnT
Just set the HOME_IGNORE_LIMITS to YES and you can use the limit switch as the home switch too. I need to finish my 5i25 configurator thingy...
JT
Last edit: 15 Mar 2016 18:39 by BigJohnT.
Time to create page: 0.411 seconds
