mesa 7i76 configuring a spindle encoder
15 Mar 2016 08:09 #71678 by Clive S
I am trying to setup up a spindle encoder to enable threading I had this working before with a PP but am now trying to configure with the mesa 7i76 I have Linux 2.7.4 using PnCConf I am getting an error message with debug, attached.
I would like to use A + B + index I have connected these to TB3 pins 7,10 and index to 13 on the 7i76
Is this correct and how do I sort the error out?
File Name: Myford_Lathe.rar
File Size:51 KB
15 Mar 2016 10:05 #71681 by andypugh
Replied by andypugh on topic mesa 7i76 configuring a spindle encoder
In the "loadrt" section you need
loadrt scale names=scale.spindle
15 Mar 2016 10:08 #71682 by Clive S
Replied by Clive S on topic mesa 7i76 configuring a spindle encoder
I will try that Thanks should PnCConf have put that in?
15 Mar 2016 10:18 #71683 by Clive S
Andy I have tried that and it gives the error in Debug lowpass.spindle.gain not found
15 Mar 2016 10:30 #71684 by andypugh
loadrt lowpass names=spindle.lowpass
16 Mar 2016 11:19 #71728 by Clive S
Andy I have tried that and it still errors. I inserted it like this:-
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
attached hal , ini and debug file
File Name: Myford_Lathe-2.hal
File Size:9 KB
16 Mar 2016 11:27 #71729 by andypugh
See how you have "names=spindle.lowpass" and then the error is "lowpass.spindle.gain, pin not found"
It's my fault, I think, but the fix seems fairly easy.
16 Mar 2016 12:24 #71733 by Clive S
Ok have have changed it to names=lowpass.spindle.gain and still the same error
16 Mar 2016 12:41 #71736 by andypugh
Hmm, comment out that line, then start LinuxCNC
Then open a terminal and type
halcmd -kf
show pin lowpass*
exit
16 Mar 2016 13:15 - 16 Mar 2016 13:18 #71738 by Clive S
Thanks for your patience Andy but commenting it out does not let me start LinuxCNC. Tomorrow I will start from scratch with the lathe config and generate a new one. with PnCConf and start again.
its the encoder for the threading I am trying to sort out I am not trying to sort out the spindle speed
Last edit: 16 Mar 2016 13:18 by Clive S.
Time to create page: 0.302 seconds
