Configuration with Timing Belt
19 Mar 2016 10:51 #71899 by spaceghost
Configuration with Timing Belt was created by spaceghost
I just finished constructing my first 3-axis CNC machine and noticed that the distance scale is way off. The X and Y axis are using GT2 timing belts and the Z axis is using a lead screw. The X-Y motion is way too big for the G-code and it looked like I needed to adjust the SCALE variable in my ini file. When I recude the number, the stepper move much slower and at low SCALE number it makes almost a pulsing sound and does not move. If I change the number back to the 8000 default the machine moves smoothly, although at the wrong scale for the G-code.
I am using a GT2 timing belt with a 16 tooth pulley with 2mm pitch. Based on the LinuxCNC documentation with 1/8 microstepping I believe the SCALE number should be 50. Is that correct? Are there other values I need to change to get this to work? I haven't been able to find complete examples of people using timing belts related to the ini config file.
19 Mar 2016 18:24 #71920 by cmorley
Replied by cmorley on topic Configuration with Timing Belt
when you say timing belt do you mean you are using the timing belt like a gear rack?
The scale setting is simply the amount of motor steps required to move one unit ( probably 1 mm in your case )
how far will the axis move with one rotation of the stepper motor?
Chris M
19 Mar 2016 20:40 #71923 by Todd Zuercher
Replied by Todd Zuercher on topic Configuration with Timing Belt
If what you describe is correct 50 steps/ mm sounds like the right scale value. You may want to consider adding more gear reduction, to get better resolution and torque.
19 Mar 2016 21:35 #71924 by gizmo6023
Replied by gizmo6023 on topic Configuration with Timing Belt
[quote="spaceghost"
I am using a GT2 timing belt with a 16 tooth pulley with 2mm pitch. Based on the LinuxCNC documentation with 1/8 microstepping I believe the SCALE number should be 50. Is that correct? Are there other values I need to change to get this to work? I haven't been able to find complete examples of people using timing belts related to the ini config file.[/quote]
Are you using two pulleys both with 16 teeth or two different sized pulleys?
I use a pulley system with a14 and a18 tooth and getting the positions wrong in step config produces what you describe.
19 Mar 2016 21:56 #71925 by spaceghost
Replied by spaceghost on topic Configuration with Timing Belt
What I am using is a single gear so there is no gear ratios in play. I am new to the CNC thing and tried to pick the preferred terminology but might have picked the wrong one.
While I continued searching online I did find a post somewhere else that gave me some hints to what I was supposed to do. Here is what I tried:
Drive Microstepping: 4
Pully Teeth: 1
Leadscrew pitch: 32
which gives 25 steps/mm. After testing this it seemed to give reasonable results. My math to get these number make (some) sense to me but I am more interested now if I did this correct and would it be correct for other situation. The problem is compounded by the fact that the Stepconf UI makes no reference to a belt system so I am left to guess which values go in which field and what formula I need to get the numbers to put in. I looks like I might have this working but it would be nice if it was easier to find a more complete expert example (or at least easier to find if it already exists).
20 Mar 2016 00:14 #71931 by cmorley
well that makes some sense.
A 16 tooth 2mm pitch sprocket will move the axis approximately 32mm every revolution.
200 step motor times 4 microstepping mode = 800 steps per revolution of the motor.
800/32 = 25 steps per 1 mm movement.
I would bet in practice you may need to adjust that a small factional amount due to pitch/diameter tolerance but test and see.
When stepconf was built that style of axis movement was not that popular.
glad you figured it out!
Chris M
20 Mar 2016 00:27 - 20 Mar 2016 00:30 #71933 by Rick G
Replied by Rick G on topic Configuration with Timing Belt
From linuxcnc.org/docs/2.4/html/config_ini_config.html#sub:[AXIS]-section
2.2.9.3 Stepper
SCALE
= 4000 (hal) Specifies the number of pulses that corresponds to a move of one machine unit as set in the [TRAJ] section. For stepper systems, this is the number of step pulses issued per machine unit. For a linear axis one machine unit will be equal to the setting of LINEAR_UNITS. For an angular axis one unit is equal to the setting in ANGULAR_UNITS. For servo systems, this is the number of feedback pulses per machine unit. A second number, if specified, is ignored.
For example, on a 1.8 degree stepper motor with half-stepping, and 10 revs/inch gearing, and desired machine units of inch, we have
Rick G
Last edit: 20 Mar 2016 00:30 by Rick G.
Time to create page: 0.244 seconds
