Mesa 7i43 initial setup issues
22 Apr 2016 17:43 - 22 Apr 2016 17:51 #73732 by novathedestroyer
Mesa 7i43 initial setup issues was created by novathedestroyer
so I am super new to 3d printing and am having some trouble. i currently have my mesa 7i43 plugged into the parallel port and the motors hooked up. but for some reason when i launch the sample configuration my motors arent turning, my epp port is enabled and i checked the connections, i am just kinda lost. any input would be great
Last edit: 22 Apr 2016 17:51 by novathedestroyer.
23 Apr 2016 09:19 #73756 by PCW
Replied by PCW on topic Mesa 7i43 initial setup issues
Does LinuxCNC run?
How is the 7I43 connected to your motors?
23 Apr 2016 11:20 #73766 by novathedestroyer
Replied by novathedestroyer on topic Mesa 7i43 initial setup issues
linuxcnc boots up, and the motors are connected via polou 4988 motor drivers
23 Apr 2016 11:31 #73767 by PCW
What firmware are you using?
Have you verified that the 7I43 to step drive connections are correct?
23 Apr 2016 14:13 #73769 by novathedestroyer
Im using the firmware SVST4_4 to try to run 4 steppers, without encoders
23 Apr 2016 14:38 - 23 Apr 2016 14:40 #73771 by PCW
Which pins of the 7I43 go to your step driver step/dir pins?
Which sample ini file are you using?
Last edit: 23 Apr 2016 14:40 by PCW.
23 Apr 2016 17:27 #73776 by novathedestroyer
while attempting to test the motors i only had 1 motor hooked in, and I just realized I had it step plugged into pin 1... which pins should i plug my step and direction into? im using the 7i43-big sample configuration for now
23 Apr 2016 18:35 #73781 by PCW
if you look at the kernel log (with dmesg) the driver lists the pinout of the firmware configuration used
24 Apr 2016 14:36 #73816 by novathedestroyer
If i am going to be upgrading this to use encoders am i going to need a new motor driver, or would what i have still work?
26 Apr 2016 09:12 #73906 by cncbasher
Replied by cncbasher on topic Mesa 7i43 initial setup issues
SVST4_4 gives you 4 encoders as default
Time to create page: 0.348 seconds
