Hello everyone:
I am new with the Linuxcnc and I intent to control a robot with linuxcnc, the version is axes_joints13 and I have some questions in ini configuration.
1.I am confused with max_velocity and max_acceleration which are listed both in [DISPLAY] and [TRAJ] section in ini file, I don't understand the difference between them and what roles dose each does in the real moving;
2.Just as I am using the axes_joints13 and the controlling object is a robot, it has a separted axes and joint configuration which is [AXES_n] and [JOINT_n] in ini file. I really know the max_velocity and max_acceleration in the [JOINT_n] section which represent the robot joint ,but how I should to set the paremeter of max_acc and max_velocity in the [AXES_n] section? also the max_acceleration and max_velocity in the [DISPLAY] and [TRAJ] section?
Maybe it is very simple In your opinion, but I really a new studier.Thank you everyone
