23 position switch for feedrate override
- BigJohnT
- Thank you received: 994
15 Jun 2016 06:10 #76053
by BigJohnT
Replied by BigJohnT on topic 23 position switch for feedrate override
Andy, is there a way to pass the number of switches you need to make the switch component a universal one?
JT
mesaus.com/
JT
mesaus.com/
15 Jun 2016 06:43 #76058
Yes, you can use "personality" as described in the manpage.
Replied by andypugh on topic 23 position switch for feedrate override
- terkaa
- Thank you received: 3
15 Jun 2016 07:09 #76062
by terkaa
Replied by terkaa on topic 23 position switch for feedrate override
good point. I will switch to this switch component at some point.
- terkaa
17 Jun 2016 10:07 - 17 Jun 2016 10:08 #76224
by terkaa
Ok,
Here is a video of this panel. It is now mostly working like it should. Jog axis select and move buttons work also spindle coolant and working light buttons. Single Block and machine lock also. And switches for overrides.
Tero
Tero
Last edit: 17 Jun 2016 10:08 by terkaa.
17 Jun 2016 10:24 #76226
Nice.
- terkaa
17 Jun 2016 15:32 #76234
by terkaa
Thank you for helping me out with configuration. I will try to connect & configure MPG next week.
Tero
Tero
Time to create page: 0.958 seconds
