Connecting HAL pins to Gladevcp panel
18 Jun 2016 09:23 #76261 by terkaa
I need to connect custom HAL component pins to Mesa IO card, my custom HAL component and also to GladeVCP panel. What is best method of doing this? Ie. I want to connect input that indicated that tool changer arm is in vertical position:
net atc_arm_is_vertical atc_panel.hal_atc_arm_is_vertical armatc.0.arm-is-vertical hm2_5i25.7i70.0.4.input-03
Above cannot be done in core HAL because it needs to be post gui. So is defining all these pins in postgui.hal ok? Or is there a way to define:
net atc_arm_is_vertical armatc.0.arm-is-vertical hm2_5i25.7i70.0.4.input-03
And then connect this name atc_arm_is_vertical to atc_panel.hal_atc_arm_is_vertical in Postgui.hal afterwards?
Tero
18 Jun 2016 09:28 #76262 by terkaa
Replied by terkaa on topic Connecting HAL pins to Gladevcp panel
Ok,
Right after posting I found solution. Using:
In core HAL and:
In Postgui.hal is ok.
Tero
Time to create page: 1.151 seconds
